Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 148
Thread: Brushed Metal Streets and Trips 2006 skin
  1. #61
    Newbie Marv87's Avatar
    Apr 2006
    Quote Originally Posted by Racergenius
    Then you can change Zoom in and Zoom out to + / - instead of the menu alternative, and perhaps change map instead of changing between two specified maps. I´m at work now and I don't remember the shortcuts, but hope you understand what I mean.
    I tried to get the zoom working last night but I had a little problem. The focus is not always on the actual map window. I'm just learning the rr setup and code so i'm not sure if there is a way to tell it to first change focus to the map and then SENDKEY {+}. Also, I'm not sure how to identify what the map window's section name is.
    I was able to get the Directions/Route Guide toggle to work as well, but I'm at work and don't remember the exact changes. I'll post them tonight.
    One more thing. I think I would want to add a "Clear Route" button too. I may look into this tonight as well.
  2. #62
    Apr 2006
    Northern Virgina, USA
    Ok, a little more info for the OSK issue. The root problem has to do with focus change. Both S&T and IE select the text in the box every time they get focus. Based on this I am assuming that they way the OSK works is to reset focus back to the app and do a sendkey for each keystroke. Good in practice for most, but not in this case.
    There are a couple of different workarounds I have found for this, but being unfamilure with the RR code I am not sure wich is best.
    1) Send a "Right Arrow" before each keystroke. This will put the cursor at the end of the text already in the box and not overwrite it.
    2) Wait until the "ENTER" key is pressed on the OSK and send what is in the text box to the form in one shot without focus change.
    3) Use the clipboard method I outlined earlier where again on the "ENTER" key press within the OSK, copy the text in the text box to the clipboard, then change focus to the app and send "CTL-V then ENTER".
    Anyone more familure with the code have any ideas?
  3. #63
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Why not just use the ACTIVATE command in RR to get focus on the windowname you need?
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  4. #64
    Apr 2006
    That is the problem, the way it seems to currently work is that every time you "Touch a Key" it sends the key immediatly to the window. This causes a focus change from the OSK to the app, in this case S&T. The way both S&T and the URL text box in IE work is that every time they gain focus they select (Highlight) what ever is in the box and replace it with the newly sent keystroke. And this cycle continues switching focus between the app and the OSK for every "Key Press".
    There are no problems, only solutions.
    7" Plython
    Via EN15000G MB
    512MB DDR2 533Mhz Ram
    80GB WD Scorpio 2.5" HD
    Panasonic Slot Load DVD
    M2-ATX PSU
    MS S&T 2006 w/GPS
  5. #65
    Apr 2006
    ahhhh....very interesting....I just got an idea from what you guys said, but I'm not sure it would work exactly.
    How about adding a button to the OSK that you would press once you finished typing in the address you want to route for.
    Example:
    - Prior to opening the Route Planner pane you press the OSK button.
    - Type in the address.
    - Instead of pressing Enter, you press a "Route" button. This button first opens the Route Planner plan which defaults to the text box needed and then press Enter for you. Thus pasting the whole address into the text box.
    Could it work?
  6. #66
    Apr 2006
    Quote Originally Posted by ITL
    My apologies for being new to the RR code, but are you saying that one can specify an internal window to a program instead of the main program window?
    So, If the + sign is what I can use to zoom in when the map window has focus, I could do something like this for the "zoom in" button?
    Code:
    B##,#,###,##,##,"ACTIVATE;- actual map window name||SENDKEY;{+}","Zoom In"
  7. #67
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    yes, you should be able to...look for a tool called Winspector Spy, which will return window names of windows objects.
    500+ full albums
    4,000+ video games
    old carPC
  8. #68
    Apr 2006
    Thank you for the that program!! That is sweet. I'm still having difficulties getting the focus to work, but I think I will be able to get it. I just need to find the right code to use.
  9. #69
    Mar 2006
    I wish I could help with this on screen keyboard issue because I would love a good fix to the problem. Currently I am using some on screen keyboard I downloaded off of google for free. You can set how transparent it is but it has no screen to show you what you have typed. Therefore unless you make the screen very transparent you can't see what you're typing until you're done. Good luck.
  10. #70
    Jul 2005
    AZ
    Quote Originally Posted by HyperSprite
    If you can still see the title bar for S&T grab it and wiggle the window and it should resize to fit inside its expected region. This can happen the first time you use S&T in RR.
    For the Task Bar issue, go to the RR settings and select "Hide Task bar"
    Chris
    I get this every time, not just the first. Any fix?
  1. Working skin for MS Streets and Trips embedded in RR
    By HyperSprite in forum RR Skins
    Last Post: 05-02-2007, 12:52 PM
  2. Software Review: Streeets and Trips 2006
    By Mattkins99 in forum The Review Palace
    Last Post: 11-14-2006, 02:47 PM
  3. Streets and Trips 2006 released!!!
    By Mattkins99 in forum Road Runner
    Last Post: 10-20-2005, 05:30 PM
  4. Microsoft Streets & Trips 2006
    By buurin in forum GPS
    Last Post: 10-12-2005, 12:08 AM
  5. Replies: 6
    Last Post: 09-29-2005, 06:50 PM
