Sounds like you're on the right path. Good luck!
Well, I've downloaded Softec's skin and installed it onto my test pc. I have to say S&T 2006 would be extremely hard to use while in car without this skin! It's a must have.
The only thing that stuck out to me was that since the SENDKEYs are all taking you through menu
navigation every time you push a button on the skin you see a quick blip of the menus. I looked into the files and S&T a little more and I was able to clean a few of them up with keyboard shortcuts vs. going through the menu.
Below is the code that I changed in the file External_GPS.skin.
For finding nearby places:
Original:
Code:
B03,0,216,60,75,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TN","Find Near"
Changed: %TN to ^d
Code:
B03,0,216,60,75,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^d","Find Near"
For GPS panes:
Original:
Code:
B04,0,290,60,75,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TP","GPS Pane"
Changed: %TP to ^a
Code:
B04,0,290,60,75,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^a","GPS Pane"
For Route Planner:
Original:
Code:
B06,0,440,60,75,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%UR","Route Menu"
Changed: %UR to ^r
Code:
B06,0,440,60,75,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^r","Route Menu"
