Page 9 of 15 FirstFirst 123456789101112131415 LastLast
Results 81 to 90 of 148
Thread: Brushed Metal Streets and Trips 2006 skin
  1. #81
    Aug 2005
    Quote Originally Posted by finnegan
    i tried but i couldnt get it to launch streets and trips -followed the second version posted here cant figure out what went wrong----renamed external gps to gps.orig but couldnt find another folder to copy gps_2006.skin into?????
    there are two seperate skins and as such two different sets of directions. Which skin are you trying to use, Mattkin's or Softec's?
  2. #82
    Feb 2006
    softecs but ill try matkins today
  3. #83
    Aug 2005
    alright with the softec skin it's really easy;
    Ok, you renamed the EXTERNAL_GPS.skin to EXTERNAL_GPS.orig, corrrect? So you take the skin you just downloaded and and extract the files to your RR skin directory, usually c:\Program Files\Roadrunner\Skins\BMV2.....
    Ok, so navigate your way to this folder and find the file labled gps_2006.skin that you just extracted there now change them name to EXTERNAL_GPS.skin. You're half way there .
    Now, launch the RRconfig tool and set the GPS Mode to external. Then fill in the GPS path field with th location of the streets & trips exe, usually C:\Program Files\Microsoft Streets & Trips\Streets.exe
    Last step is to enter this"- Microsoft Streets & Trips" in the GPS window name field. That's it.
    If you still want to try Mattkins99 skin please do, both are great skins. Good luck
  4. #84
    Newbie Marv87's Avatar
    Apr 2006
    I got the Uboard working!!! That was a great find dasha!
  5. #85
    Feb 2006
    still cant get either to work i must have f---ed something up.....
  6. #86
    Mar 2006
    Finnegan I swear i've done everything right as well when using the s&t skin (the first one posted) yet from the menu page it still won't launch the gps. I have found if I go to the music page though and then click on the globe from there it works perfectly. Maybe someone could explain the solution to me and maybe finnegan you can see if you're having the same problems.
  7. #87
    Apr 2006
    Quote Originally Posted by cneeley
    which version of RR r u running?
  8. #88
    Mar 2006
    i tried doin the smae thing and i think i ran into the same problem. the thing was i tried to do both , but you could only do one. once i did only one the second one. it worked beautifully
  9. #89
    Mar 2006
    Colorado, but Canadian!
    Question Opening up an old-ish thread...
    Quote Originally Posted by dasha877
    Got an OSK working for both IE and S&T. Turned out to pretty easy. Just use the Uboard transparent OSK. configure it to align on the bottom (hit CAPS then CFG). This OSK alignment will allow you to get to the address tool bar or menu in IE and S&T. But that wont be all that necessary if you invoke the OSK this way:
    in the web skin:
    XXX,XXX,XXX,XXX,XXX,"ACTIVATE;Explorer||RUN;C:\UBo ard\UBoard.exe",""
    in the streets skin:
    XXX,XXX,XXX,XXX,XXX,"ACTIVATE;Microsoft Streets & Trips||RUN;C:\UBoard\UBoard.exe"
    It works. And the nice thing about Uboard is that it will go away if activated again from the skin button. You can therefore toggle back and forth easily.
    You can get UBoard in CFX_Tools. Just do a search. Please post your results and enhancements.
    Hello all. I like this skin and from what I can tell, this fixes the OSK issue. My question is how?
    Is UBoard another piece of software that replaces the OSK built in?
    Do I add those lines of code to the skin files or replace something?
    I don't know much about this as you can tell.
  10. #90
    Jul 2005
    AZ
    Quote Originally Posted by 2k1Toaster
    Yes, you'll add those lines to the skin files. Just look for the lines that call out the OSK and replace the portion following position reference (what I labeled XXX,XXX,XXX,XXX,XXX). There's an article or two on skin basics. Do a search and you'll find them.
  1. Working skin for MS Streets and Trips embedded in RR
    By HyperSprite in forum RR Skins
    Last Post: 05-02-2007, 12:52 PM
  2. Software Review: Streeets and Trips 2006
    By Mattkins99 in forum The Review Palace
    Last Post: 11-14-2006, 02:47 PM
  3. Streets and Trips 2006 released!!!
    By Mattkins99 in forum Road Runner
    Last Post: 10-20-2005, 05:30 PM
  4. Microsoft Streets & Trips 2006
    By buurin in forum GPS
    Last Post: 10-12-2005, 12:08 AM
  5. Replies: 6
    Last Post: 09-29-2005, 06:50 PM
