Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 148
Thread: Brushed Metal Streets and Trips 2006 skin
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    Hi all,
    For those of you using the Brushed Metal skin and want to use MS Streets and Trips 2006, here's are the files you need. Thank Hypersprite for figuring this out for Streets and trips 2005... I've only created Brushed Metal skin and used the 2006 version.
    http://www.seattle5s.com/BrushedMeta...dTrips2006.zip
    The Zip file contains the following:
    Streets.skin
    Streets2.skin (more buttons)
    You'll need to modify 3 files of the Brushed Metal .skin files.
    menu.skin
    Look for the following line:
    B06,418,298,369,116,"GPS","GPS"
    This is currently line 11, and change it to:
    B06,418,298,369,116,"LOAD;STREETS.SKIN;Streets;C:\ Program Files\Microsoft Streets & Trips\Streets.exe;Microsoft Streets & Trips","Streets"
    exit_menu.skin
    B01,000,013,411,057,"EXIT","Exit"
    This is currently line 6, and change it to
    B01,000,013,411,057,"CLOSEWINDOW;Microsoft Streets & Trips||EXIT","Exit"
    Audio_Player.skin
    B04,206,165,64,84,"GPS",""
    This is currently line 9, and change it to
    B04,206,165,64,84,"LOAD;STREETS.SKIN;Streets;C:\Pr ogram Files\Microsoft Streets & Trips\Streets.exe;Microsoft Streets & Trips","Streets"
    The following was written by Hypersprite to better setup Streets and trips so that when initially opened, it is best setup for in car use on a small touchscreen
    [Open up Streets and trips,] position the map so it opens on your home town at a decent zoom level, or wherever you happen to drive the most. Now drag the Drawing and Standard menus to undock them and place them out of the way, this way when you open up Streets in Road Runner they will not take up usable space. Also go to View, Toolbars, Location and Scale and uncheck it (it seems to remember this option on future openings where as the other ones, sometimes yes, sometimes no.
    For maps that are not as harsh at night and easier to read I the day time, try changing the map style at View, Map Style, Terane Map, it just works a bit better (although still not 3D). Now save your template to C:\Program Files\Microsoft Streets & Trips\Templates as New North American Map.stt
    Buttons
    The Buttons on the left are as follows.
    Exit
    Zoom +
    Zoom _
    Night Mode
    Toggle GPS Pane
    Toggle GPS on/off
    GO (reroute from current postion)
    Open/Close bottom button bar
    Bottom row
    Music
    Toggle Route Planner
    Day mode (Actually Terrain mode)
    Toggle Location and Scale toolbar
    Toggle Find nearby places pane
    Mute
    Volume -
    Mute (volume level is a button as well)
    Volume +
    Previous Track
    Stop
    Play/Pause
    Next Track
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
    Oct 2005
    Albuquerque, NM
    Another Streets BM Skin
    Here is another Streets & Trips 2006 skin based on the Brushed Metal skin.
    I have been using it for about three weeks now including a long trip last week an everything seems to be working. The OSK it calls up is the one used in WindowsXP. I Also included a Brushed Aluminum variant of this. Enjoy!!
    http://home.att.net/~cougar428/GPS_ST2006_BM_skin.zip
    http://home.att.net/~cougar428/ST2006_BM_PSD.zip
    http://home.att.net/~cougar428/GPS_ST2006_BA_skin.zip
    http://home.att.net/~cougar428/ST2006_BA_PSD.zip
    Installation Instructions;
    Streets & Trips 2006 should be fully installed and functional prior to installing the skin.
    Using the RRConfig Utility, enter the following information in the GPS Pane;
    GPS Mode = External
    GPS Path = C:\Program Files\Microsoft Streets & Trips\Streets.exe (or your install directory if custom install)
    GPS Window Name = - Microsoft Streets & Trips
    Copy all files beginning with the name “GPS_ST2006… to your Bushed Metal skin directory.
    Rename your External_GPS.skin file to External_GPS.orig
    Copy the file named GPS_ST2006.skin to External_GPS.skin
    Load RoadRunner, reset your skin and test the GPS functions.
    All functions are documented in the “tool tip” section of the respective .skin file.
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Nice work - what resolution are you running in the car? Is it on a small screen? Have you also used iGuidance - how does it compare in your opinion? Any screen shots of it telling you where to turn next (in large print), etc.? I'm really curious about this now.
    Sep 2005
    http://www.microsoft.com/streets/Pro...s.aspx?pid=001
    not a picture of the directions embedded in RR, but use your imagination.
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by Thrasher
    Thanks, seen it, but not helpful.
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Will S&T re-calculate the route if you leave the path?
    I've had Mappoint 04, now use iGuidance, but have yet to put S&T 06 in the car b/c of this.
    EDIT: their demo video shows the ability to re-calculate, but it has to be done with a click. iGuidance will re-calculate without any interaction.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    just downloaded the skin and was looking at some of the functions...
    If a keyboard shortcut exists to re-calculate route, I'd add a button to my skin for this and use S&T 06. How are you guys finding the keyboard shortcuts? Sorry, I haven't played with the software much, yet.
    Also, is the SENDKEYS function working 100%? It is so sketchy with iGuidance that it's pretty much worthless. I'm hoping that it works smoothly with S&T since there is probably a good SDK.
    500+ full albums
    4,000+ video games
    old carPC
    Oct 2005
    Albuquerque, NM
    Hark;
    The screen resolution is 800x600 on a 10.4 screen”. I use a Viewsonic ViewPad 1000 for my carpc. It uses a touch screen interface and is a totally self contained pc, 800mhz Celeron.
    I have never used iGuidance. I have another program on my PocketPC called Ostia. Its way to small and requires a computer to generate the maps for travel.
    I started with Streets & Trips 2005. I like the look and feel, but it was limited on live directions during travel. The 2006 version solved a lot of those issues.
    There is a review of S&T 2006 at the following thread. I will post some other screen shots showing various driving direction windows when I get home later tonight.
    Streets and Trips 2006 released!!!
    ITL;
    S&T will recalculate the path from your current positions it is the button on the left side that looks like a dotted U-Turn. The reroute does require user action, other wise it just tells you “OFF ROUTE”.
    All of the functions in the skin use the programs keyboard short cuts in the RoadRunner sendkeys function. Almost every function in S&T has a short cut.
    All;
    Key Definitions.
    Top row left to right – all music related
    Previous track, stop, play/pause, next track --- Vol-, Mute, Vol+, Full Screen Toggle (widens over both side panels)
    Left Side Top to Bottom
    Tool bars toggle
    OSK, not functional
    Find Points of Interest (new side pane)
    Open GPS Pane
    Reroute from Current Position
    Route Planner Pane
    Repeat Last Instruction
    Right Side Top to Bottom
    Zoom to Selected Point
    Zoom In
    Zoom Out
    Zoom to Entire Route
    Day/Night Toggle
    Route Text/Next Turn Pane Toggle
    Return to RoadRunner
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    I'm assuming some of the mappoint skins/menus are being used for route planning etc...is this correct?
    This is what I'd hope for, anyway. Mappoint integration is excellent with RR...From first look, it just doesn't seem as if S&T is as tightly integrated.
    500+ full albums
    4,000+ video games
    old carPC
    Oct 2005
    Albuquerque, NM
    ITL;
    I don’t use any of the MapPoint or other GPS skins. I do all my route planning using the native S&T menus and functions at home or using a wireless keyboard and transfer the directions file to the carpc. I only programmed the functions into the skin that I felt I would use while actually driving. The only integration available from RR is what you can program from using SendKeys, which is actually quite a bit.
    Hark;
    Here are several screens showing some of the driving functions/directions;
  1. Working skin for MS Streets and Trips embedded in RR
    By HyperSprite in forum RR Skins
    Last Post: 05-02-2007, 12:52 PM
  2. Software Review: Streeets and Trips 2006
    By Mattkins99 in forum The Review Palace
    Last Post: 11-14-2006, 02:47 PM
  3. Streets and Trips 2006 released!!!
    By Mattkins99 in forum Road Runner
    Last Post: 10-20-2005, 05:30 PM
  4. Microsoft Streets & Trips 2006
    By buurin in forum GPS
    Last Post: 10-12-2005, 12:08 AM
  5. Replies: 6
    Last Post: 09-29-2005, 06:50 PM
