Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: send commands to apps not working?
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by ITL
    Okay, so I'm trying to get Mobile Emulator to run inside of RR, and I was told I need to add this button (and the associated string of commands/parameters):
    B06,3,312,275,78,"RUN;C:\playfile.exe|C:\Music.wav ||LOAD;games.skin;RUN;C:\Program Files\Mobile Impact\me.exe;Mobile Impact",""
    But I'm not sure where this should go. The file to RRSource.zip seems to be down. Can I get a little help?
    Ok, my mistake the playfile is not needed (nicked the code from liquid smokes skin)
    B06,3,312,275,78,LOAD;games.skin;RUN;C:\Program Files\Mobile Impact\me.exe;Mobile Impact",""
    this is a button command in one of your skin files.
    Basically you need to create a button on a skin and put that code in.
    Then you need to have a games.skin file and the associated skins to go with it.
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    hahaha... I still see a mix of the load command and the run command with the impropper separator ( instead of || as it should be... you can launch applications using the LOAD command ONLY or using the RUN command SEPARATELY from the Load command... but in no way the RUN command should be "part" of the LOAD command as you guys have been posting here..
    Ride Runner RR's Myspace
  3. #13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by guino
    so it should be
    B06,3,312,275,78,LOAD;games.skin;games;C:\Program Files\Mobile Impact\me.exe;Mobile Impact",""
    then?
  4. #14
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    the upcomeing update of the skin has support for mobile emulator and a skin for mobile emulator to use with road runner.
    The code for that button that im using is this
    "RUN;C:\playfile.exe|C:\Music.wav||LOAD;N64.skin;RUN;C:\Program Files\Mobile Impact\Me.exe;Game Emulator"
    works everytime for me.
    beer replenishment fund
    mp3car live search
  5. #15
    Aug 2003
    Chicago
    Quote Originally Posted by Enforcer
    so it should be
    B06,3,312,275,78,LOAD;games.skin;C:\Program Files\Mobile Impact\me.exe;Mobile Impact",""
    then?
    so only the path to a file is needed to run it? Ive been using the run command with load on a lot of stuff.
    mp3car live search
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by liquid_smoke
    I know, I knicked mine off you
  1. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  2. No voice commands
    By Wadda in forum FreeDrive
    Last Post: 10-15-2005, 08:06 AM
  3. help lilliput usb not working!!!
    By pardoe16V in forum LCD/Display
    Last Post: 10-14-2005, 04:28 PM
  4. send signal to RCA (not the screen)
    By lazynok in forum LCD/Display
    Last Post: 08-12-2003, 12:47 AM
  5. Someone please help 10 hrs wasted working on 4 x 20 Character LCD
    By Martin S. Shepherd in forum LCD/Display
    Last Post: 05-31-2001, 11:25 AM
