Results 1 to 3 of 3
Thread: Problem embedding MapMonkey after reboot/hibernate
    Mar 2004
    Stockholm, Sweden
    The latest versions of RR seem to have problems (on slow systems) when embedding MapMonkey the first time MapMonkey is started after reboot/hibernate. If i exit to Main Menu and then reenter GPS, it re-embeds fine. Also if i close MapMonkey and restart it it is working. MonkeyTalk however is working, all the MM labels are updated...
    I have seen this on both the car PC (EPIA M10000 with a slow hard disk) and (sometimes) on one of my home PCs (also not very fast)...
    Is there something that can be done about this (except me changing the HD to a faster one...)
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    there are a few settings that help on embedding of MM.. read the GPS faq to see about them..
    Ride Runner RR's Myspace
    Mar 2004
    Stockholm, Sweden
    I have no problem embedding MM when for instance I launch it prior to RR, the problem is that MM takes too long to load the first time after a reboot/hibernate. I have fixed it by adding a Sleep 5000 in mdRoadRunner.bas, right after you launch MM. Then it works 100%.
    It will probably work with less than 5000 ms, but i have yet to try out the optimal time.
    If no one else has this problem i am quite happy to change this myself, so dont worry about it...
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 09:28 AM
  3. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 11:50 AM
  4. audio problem
    By tiburonputer in forum General Hardware Discussion
    Last Post: 08-11-2005, 03:58 PM
  5. Problem with MapMonkey and CF1.4 hibernation
    By Bokky in forum Centrafuse
    Last Post: 08-02-2005, 08:25 AM
