Page 10 of 25 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 243
Thread: Setvol and Speed Attenuated Volume Control
  1. #91
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Regarding stand alone version: You mean seperate to Road Runner? If so, no sorry. Use Road Runner, it's the best Front End out there ;-)
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  2. #92
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Just got back from a test and the new one will not work at all
    It sets the vol to 100% all the time and you can not change any
    Really the other one worked very well and balanced I could not believe how well it worked (drove around 4 hrs). I would switch back to it if I were you and save yourself a lot of time and just add a way to turn it off with a button or disable at 0mph for like 10 seconds and fix the 70mph setting.
    2001 S10 ZR2
    Chucks Skin - to old
  3. #93
    Mar 2004
    Cambridge, MA, USA
    Ok, so I've just got the latest source code so have 'merged' these changes and others.
    I've decided to abandon the acceleration idea, at least for the moment.
    I shall be issuing a BETA 3 (via the website) in a little while. This BETA 3 will include:
    - The latest changes to the Speed attenuater stuff
    - Phidget Relay buttons with momentory action
    - GPS Gamma config and functionality
    [Edit] Ok, latest 'fixed' and 'merged' code uploaded. Please give it a try including the RRConfig.
    Andrew
    06 Volvo XC90
  4. #94
    Mar 2004
    Cambridge, MA, USA
    Regarding the ability to toggle the Auto volume stuff. Is anyone against having a 3 state MUTE button?
    E.g. Mute -> Speed Att disable (unmute) -> Unmute
    Obviously this would only be a 3 state button when Speed Att. is in use.
    Any other suggestions?
    06 Volvo XC90
  5. #95
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Well I tried out the new update and it seems to be working but I only went out for a very short run so tomorrow I will test it good. (4:30 AM) and the gamma.
    I do not know if you could do this or not maybe press and hold the mute to Speed Att disable and hold again to enable (like the presets) that way you would always have mute if you need it.
    2001 S10 ZR2
  6. #96
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by skippy76
    bah, you stank!
  7. #97
    Mar 2004
    Cambridge, MA, USA
    Well, as long as I stank or stunk but don't stink.
    06 Volvo XC90
  8. #98
    Mar 2004
    Cambridge, MA, USA
    Excellent, thanks for the help with testing... I trust it was the BETA 4 that you just downloaded. I noticed that the code did not have the GPS GAmma stuff in so I compiled it a little while ago and uploaded it.
    Regarding the holding down the Mute button, unfortunatly that won't be possible. The 3 state MUTE button is looking like the most likely option.
    Once we have confirmed that all is working well I'll add the method for disabling the Speed Att. (e.g. with MUTE button) and then shall get Guino to release it.
    06 Volvo XC90
  9. #99
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    The new zip file says there is an error in it and will not let me unzip
    2001 S10 ZR2
  10. #100
    Mar 2004
    Cambridge, MA, USA
    Sorry, must have had a problem when FTPing it. I'm just reftping it now....
    [Edit]. It's there now and appears to be ok. This is BETA 4.
    06 Volvo XC90
