Page 2 of 25 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 243
Thread: Setvol and Speed Attenuated Volume Control
  1. #11
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    My bad Link is now fixed
  2. #12
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    ok, i just finished the test drive
    works pretty good, there are some issues though. I never tested the previous version you made with multiple files so i dont really have anything to compare it to.
    off the line, everything is fine and the volume changes at the set points.
    stopping the car at a street corner though, the volume cuts harshly from 90%to20%, i think it may not be updateing quite fast enough. It seems like it takes about 5sec after i stop to recognize im not doing 60mph anymore. If i stop slower this isnt a issue. Not sure if the size of the flash speedo is slowing it down or not, but the speedo that me and you worked on that was much smaller updated faster than this one, so it may be the size or the added functions, not sure.
    If you can get it to change the volume more gradually (esp when stopping) then i would say its ready to go. Also, do you think it would be better to change the volume of winamp and not the wav or master? That way, when getting voice directions from IG, the voice stays at the same volume?
    beer replenishment fund
    mp3car live search
  3. #13
    Mar 2005
    Concord, California
    Sweet, thanks for testing!! When you say that it's slower than the one we worked on, do you mean that the needle is slower to respond or are you referring to the volume changes? It's set to SpeedCheck=3 in the .txt so setting it to 1 second should speed it up a bit. Also, you can change the Audio-line to winamp in the txt as well. I'll try and find a way to make the changes more gradual. Thanks again for testing m8
  4. #14
    Aug 2003
    Chicago
    Quote Originally Posted by DiNASTY
    np, you've helped me on quite a few things, glad to help out.
    the needle seems to be slower, much more when im stopping, but i think the stopping is because im stopping fast. This also applies to the volume changes when im stopping. When i stop fast (not super fast, just normal for me i guess) there is about 4-5 sec before the volume goes down to 20%
    Ill change the SpeedCheck to 1 and go test it again, need to get some gas anyway. Ill let you know if that improves it.
    mp3car live search
  5. #15
    aco
    aco is offline
    Oct 2005
    UK Yorkshire
    love that speedo any chance of having it as an app in rr or something similar
    Andy
  6. #16
    Raw Wave
    Jun 2004
    On the beach
    You should be able to just embed the app in RR
  7. #17
    Aug 2003
    Chicago
    ok, test drive two.
    changeing the speedcheck to 1 helped a lot, i think the only thing left would be the gradual volume.
    Are the number of triggers fixed? On the low end of the speedo 0-40 i would like to have more triggers, i reach 20mph almost instantly, plus with the speed that the gps is reporting and my actual speed at low speeds is off because gps needs time to get a more accurate reading of how fast your going. I notice normally about a 5-10 mile difference between my acutal speed and what the gps reports as my speed at low speeds (this has nothing to do with your stuff), so i would like to tweek the triggers on the low end to better match up with my actual speed.
    But everything seems to be A OK.
    man, it was nice to drive around and not have to constantly fiddle with the volume, i felt free to concentrate on other things, like driveing makes me want to go back out for another drive
    mp3car live search
  8. #18
    Aug 2003
    Chicago
    Quote Originally Posted by aco
    Andy
    its not an app, its a flash file, so you can put it anywhere you like. Im not sure how the final version is going to work.
    mp3car live search
  9. #19
    Mar 2005
    Concord, California
    Sure, here is just the speedometer without all the volume stuff in it. Just extract to your skin folder and call the skin with "LOAD;SSV.skin". It's discardable so no need to worry about performance (Thanks guino)
    Speedometer Only
  10. #20
    Mar 2005
    Concord, California
    LS, they're fixed ATM but I can add as many as you need. I'll put say... 10-20 triggers in the next one.
