Page 22 of 25 FirstFirst ... 1213141516171819202122232425 LastLast
Results 211 to 220 of 243
Thread: Setvol and Speed Attenuated Volume Control
  1. #211
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by skippy76
    Nice... so this shows the current volume level right...???
    Yup, volume in both % and slider indicator. Now all I need is speed attenuator on and off indicator.
    2001 S10 ZR2
    Chucks Skin - to old
  2. #212
    May 2005
    Germany
    @Chuck
    Is this your mute button or a button only for the speed volume function?
    Ti-ejtsch
  3. #213
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by Ti-ejtsch
    @Chuck
    Ti-ejtsch
    mute button
    2001 S10 ZR2
  4. #214
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by Chuck
    Also I have a gamma button in my skin and it will not do anything now with the setting on –use built in gamma with GPS
    Chuck- where is this setting located? I didn’t see it in RRConfig. Perhaps an .ini file somewhere.
    Quote Originally Posted by bmo
    I was using Xport for the gps between IG and net stumbler. I added one more for RR, and had to change to mappoint instead of external gps in RR config. If I didn't the gps com port setting would default back to zero every time I saved it. The only thing now is that my buttons in gps skin are not working right... I'll have to figure that out later.
    Brian
    nope same problem here. I had to change from external to mappoint, then in exectbl file add this line
    "GPS","LOAD;EXTERNAL_GPS.skin;Navigation;C:\Pr ogra m Files\iNav\iGuidance\iGuidance.exe;iGuidance".
    Brian- I had this happen the other day. I was trying to get Mappoint and iGuidance to both work from RR, not at the same time, but to have the option of either. I settled with just having iG, b/c the COM port kept reverting to zero. I see your workaround, but any idea what causes this? Even with xPort, I couldn’t get both MP and iG to work with RR. I have to choose one or the other.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  5. #215
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    ITL- you need skippy76 beta 9a to make this work both RR and config
    works great
    http://carpc.harteveldt.com/
    2001 S10 ZR2
  6. #216
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Yep, also as an FYI. Tim has been adding some functionality to my code, hence the delay in releasing. He is in the progress of merging his code so I imagine that we will have a Beta 10 out very shortly.
    I'm also planning on adding the GPS vol icon for BETA 10 too.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  7. #217
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    k, I'll give it a shot...yay, another process to run :sarcasm:
    whatever gets the job done, I guess. Thanks, Chuck :thumbsup:
    500+ full albums
    4,000+ video games
    old carPC
  8. #218
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    2001 S10 ZR2
  9. #219
    Mar 2004
    Cambridge, MA, USA
    Please see last post that I posted in this thread:
    To Do List for Road Runner - Skippy76
    as I want people to provide feedback on how the GPS Vol and also the GPS Gamma should work...
    06 Volvo XC90
  10. #220
    May 2005
    Germany
    Has someone tested Tim´s new rr_gain_sp3?
    Ti-ejtsch
