Page 6 of 25 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 243
Thread: Setvol and Speed Attenuated Volume Control
  1. #51
    aco
    aco is offline
    Oct 2005
    UK Yorkshire
    well said ls
  2. #52
    dru
    dru is offline
    Newbie dru's Avatar
    Nov 2005
    West-Germany
    Why don`t U open a new Thread called: RR vs. CF?!?
  3. #53
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by dru
    because the winner would be frodoplayer
    Lez, more widely known as flez1966
  4. #54
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by GizmoQ
    Yea, I'm having nearly the same problem. FreeDrive does not support GPSSPD. So I've been testing with MM. I also usually use line out to my headunit, but havent been able to figure out how to set up SSV for it so I've been testing with wave out and like you said, Chuck, it seems to be fighting with itself.
    Another thing I noticed is volume control through RR is no longer possible. If I change it up or down SSV changes it back to its setting. I originally didnt think this would be a problem (see my first post) but it is. And I could envision those without a head unit not being happy at all.
    I guess what I'm saying is using SETVOL is not quite the best method.
    I use IG for my map and set RR config for mappoint on com 4 them start my IG like this in my ExecTBL.ini
    "GPS","LOAD;EXTERNAL_GPS_ig.skin;Navigation;C:\Pro gram Files\iNav\iGuidance\iGuidance.exe;iGuidance"
    If I need to change the vol I just turn off the SSV
    I Think SSV is grate if it would work in all the skins
    Not only that but I already modded all my skins for it
    2001 S10 ZR2
    Chucks Skin - to old
  5. #55
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    I just wrote an app, my first carpc app actually(q cheerleaders) for using joystick as a mouse, but it also reduces volume to 30% when a button on my joypad is held in, I plan to wire the joystick button via a realy to the dome light.
    when the light goes out the volume comes back up, provided its not been adjusted while the door was open, if so then it leaves it alone and uses that as the new volume next time.
    It would not be too hard to adapt the app to take the speed from the gps data stream and reduce volume according to settings in an ini file, say 25 user defined settings for every 5mph upto 125.
    that way it would be a windows app, and would control everything etc so would work with all front ends/mp3 players etc.
  6. #56
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    THE PREVIOUS SOLUTION: DiNASTY came up with a set of flash files for me that read GPSSPD and increase/decrease the master volume 20% at 30, 50, and 70MPH depending on whether accelerating or decelerating.
    where can i get these files to try out?
    2001 S10 ZR2
  7. #57
    Nov 2004
    St Louis
    Quote Originally Posted by Chuck
    Pull them from this post.
  8. #58
    dru
    dru is offline
    Newbie dru's Avatar
    Nov 2005
    West-Germany
    *still waitin' for the km/h version to try out....
  9. #59
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Today I tried out the old three-file set up and the new one and in my opinion the new fixed is the way to go. With the old ones if you start switching skins and other stuff it gets mixed up and you end up with a high or low vol. With new one (if it would work in all skins) if it gets mixed up it would at least get back on track by itself without fiddling with the volume control.
    I set it up to use the master volume and if you need to fine adjust it I just change the wave, line, aux or mechanical volume control.
    And with people without mechanical volume control could setup there skins volume with wave, line or aux volume.
    Maybe you could have the SSV.swf file write to the SSV.txt file to tell it if it is on or off and have a second SSVSkin.SWF that would only read that SSV.txt file and control the volume and put the SSVSkin.SWF in all skins.
    After using this I think it is a must have
    Thanks DiNASTY
    2001 S10 ZR2
  10. #60
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Now that's PHP stuff... I could probably use the CUSTOMLABELs in RR to do something like that. The initial idea was to put SSV on one skin and GPSSPD labels on every skin, but from the comments thus far I take it that doesn't work.
