Page 7 of 25 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 243
Thread: Setvol and Speed Attenuated Volume Control
  1. #61
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Once you get out of the skin with the SSV in it the speed stops updating and SSV will keep sending the same volume setting.
    2001 S10 ZR2
    Chucks Skin - to old
  2. #62
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Could this work without the graphics like the old ones but use the text file for settings and fixed volume levels?
    You already have a separate Speedo.
    No off button but that way if anyone does not like it they could just delete the text file.
    2001 S10 ZR2
  3. #63
    Feb 2004
    maybe you could help me... for me the SETVOL of the Line In is not working. Has someone ever try that?
  4. #64
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Line would not work for me
    2001 S10 ZR2
  5. #65
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by DiNASTY
    Now that's PHP stuff... I could probably use the CUSTOMLABELs in RR to do something like that. The initial idea was to put SSV on one skin and GPSSPD labels on every skin, but from the comments thus far I take it that doesn't work.
    humm, i havent tried it like that, but i do already have a few GPSSPD labels on different skins, but dont think it worked when i left the skin with the speedo.
    For me, this is something i would use 100% of the time, so i dont think i would ever turn it off (unless something was wrong, which is very low likelyhood).
    If i had to stick it on everyscreen, thats fine with me too, but i would want a version with no graphics (1transparent pixel) so its lite.
    beer replenishment fund
    mp3car live search
  6. #66
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Not wanting to stear away from the seperate app idea, if anyone wants to write a small amount of VB code we can add this functionality directly into RR. I'd have done it by now but was busy with wedding stuff.... and also doign the IG stuff.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  7. #67
    Raw Wave lostreception's Avatar
    NY
    heres something that mayhelp with the process i have the .fla if u want em i was gonna make the graphic load from an external jpg and the amount of lines in dynamically created so i can change a var from 150 to 110 and only have 110 lines drawn dinasty LMK if u want the source i was gonna use this to pull a text var into flash from another program but it got nowhere with it because i cant code programs just some flash
    Attached Files Attached Files
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  8. #68
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    If you keep the off button I think maybe there should be a setting in the SSV.txt file so when you do turn it off it will go to a set fixed volume.
    I guess I will try again to make one skin to do xm, music, radio and may be tv by using switch buttons labels and other tricks.
    2001 S10 ZR2
  9. #69
    Mar 2004
    Cambridge, MA, USA
    Does the increase in volume against speed need to be iniar or is it best if the increase in volume is a function against speed? Aterlnativly, I wonder if it is actually a function against aceleration?
    Reason I ask is that I imagine that a volume percentage at 0 mph / kph would be decided upon and then a volume percentage at 70 mph / kph. Obviously it's pretty simple of have a liniar incrase in volume, but in reality I would think that the volume would need to be an initial rapid increase and then increase slower at higher speeds.
    06 Volvo XC90
  10. #70
    Mar 2004
    Cambridge, MA, USA
    Ok, shall make a mod to RR to make the increase linear. The speed shall be taken from the GPS readings. I figure that 4 config values are needed:
    speedatt (1 or 0 to enable or disable)
    speedattunit (either mph or kph)
    speedattzero (percentage volume at zero speed)
    speedattmax (percentage volume at 70 mph or 110 kph)
    06 Volvo XC90
