Page 8 of 25 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 243
Thread: Setvol and Speed Attenuated Volume Control
  1. #71
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by skippy76
    Ok, shall make a mod to RR to make the increase linear. The speed shall be taken from the GPS readings. I figure that 4 config values are needed:
    speedatt (1 or 0 to enable or disable)
    speedattunit (either mph or kph)
    speedattzero (percentage volume at zero speed)
    speedattmax (percentage volume at 70 mph or 110 kph)
    Will that be master volume?
    2001 S10 ZR2
    Chucks Skin - to old
  2. #72
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    I was assuming master volume as then we would be controlling all output accordingly.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  3. #73
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Sounds like a winner to me
    2001 S10 ZR2
  4. #74
    Mar 2004
    Cambridge, MA, USA
    If I find some motivation this evening I'll probably get a Beta out for some poeple to test for me... any volunteers?
    06 Volvo XC90
  5. #75
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Me Me Me and ME
    7 more post and you will be up there with me
    2001 S10 ZR2
  6. #76
    Mar 2004
    Cambridge, MA, USA
    BETA version to be tested...
    Ok, here is a BETA for someone to try. I've not tested it so please let me know.
    I suggest you backup your RR.exe, RR.ini and RRConfig.exe. Replace your RR.exe and RRConfig.exe with the two files in the zip file which can be downloaded from my website: http://carpc.harteveldt.com
    Run RRConfig.exe and configure the Automatic Speed Attenuation section. BTW, you'll need your GPS configured in the GPS section too.
    Run RR and go for a drive... let me know...
    BTW, as I've not managed to get the latest source code of Guino, this is built on the previous verison (10-16-05). Assuming all is good, I shall get this merged into the next release.
    Andrew
    06 Volvo XC90
  7. #77
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Man that was fastttt
    Ok I just down loaded and installed on my desktop and set up for mph 0=30 70= 80 but I do not have a GPS on this pc
    First I see you set it up with “WINAMPVOL” and not "MASTER” so it will not adjust all line in’s.
    Second even though I set the 0mph to 30 it turn it to 0 but it is doing something – maybe because I have no GPS on this pc
    Will there be a command to turn it on and off later?
    So the next step is to install in my truck and I will surely let you know how it works.
    Thanks skippy76 if this works out i think it will be a big improvement to RR.
    2001 S10 ZR2
  8. #78
    Mar 2004
    Cambridge, MA, USA
    Hi,
    Thanks for the quick feedback. I'm just taking a look at the source. Think I may have called the wrong setvolume proc so am double checking.
    As for using this without a GPS... yes, if you have no GPS then it will not work. However, I suspect if the speed is zero then it should set the volume to the Speed 0 volume setting.
    Andrew
    06 Volvo XC90
  9. #79
    Mar 2004
    Cambridge, MA, USA
    Ok,
    Yep, have fixed the code so that it alters the main volume control rather than the winamp volume control (screw up on my behalf...)
    I've uploaded the new version of the ZIP file...
    Andrew
    06 Volvo XC90
  10. #80
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Now it is using master and it is setting it to the 30mph setting but now I am getting errors such as 19650, 52400 and the error number changes depending on the setting of the volume at start up.
    lots better
    2001 S10 ZR2
