Results 1 to 4 of 4
Thread: vis not emmbed in bmv2
    aco
    aco is offline
    Oct 2005
    UK Yorkshire
    sorted but no fullscreen /vis not emmbed in bmv2
    milkdrop vis will not emmbed into bmv2 only shows up in top left corner, beds into mc skin ok but prefer bmv2.
    also when put on fullscreen it just flashes between frontend and vis, then my screen gets upset after a min of this
    been all morning still no clue
    Cheers
    Andy
    aco
    aco is offline
    Oct 2005
    UK Yorkshire
    sorted 1 thing out the embedd bit just had to alter x,y,w,h in ini file, just strugglling with full now
    Cheers
    Andy
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    there's a bug on the AVS plugin that the double-click to full screen doesn't work (it kicks off) if the mouse is within the boundaries of the new screen's resolution... if you make the x,y,w,h to cover your entire playlist, set the screen resolution to say 512x320 and double click on the AVS as far to the bottom right as you can, this should go full screen and stay.... I have posted this on the winamp forums but never did get any repplies... apparently nobody gives a **** about using winamp on touchscreen systems..
    Ride Runner RR's Myspace
    aco
    aco is offline
    Oct 2005
    UK Yorkshire
    sorry if i am being thick but i am using the milkdrop not avs, anyway i have put a requst up for someone to alter one of my skins so i can adjust the size in the ini file instead
    Cheers
    Andy
  1. RR and Winamp VIS...
    By DaPCWiz in forum Road Runner
    Last Post: 11-01-2005, 06:17 PM
  2. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 08:14 PM
  3. Replies: 2
    Last Post: 09-28-2004, 07:43 AM
  4. Can fullscreen vis
    By pip in forum FrodoPlayer
    Last Post: 07-30-2004, 01:05 PM
  5. ESC Program for Vis
    By veetid in forum FrodoPlayer
    Last Post: 06-12-2004, 03:43 AM
