Liquid, if I could get more ram I would, memory is cheap except in my body/mind and that has been costly in the past
. My HP E-PC has only 1-slot and all I can find that was compatible after several tries was a HP branded 256 stick and that wasn't too easy to find.
With the previous post of 128 meg in the scenario, it would definitely be a problem. If they are running RR in the startup folder of XP, then this might compound the problem. I know I added some timing to my startup of RR on the initial
windows bootup for TCP/IP,
bluetooth, etc and things have smoothed out and once you get use to it, the time delay isn't that bad.
Winamp can be a process hog in visualization mode or at least mine is, it shot up to 82+% and peaked at 96% while I was running it with RR/Phoco, etc without it shows around 22-27% CPU and about 29% memory usage.
Forgot to mention that if Winamp's option is checked for traybar icon, Phoco will have problems, just minimize it the first time.
