Results 1 to 2 of 2
Thread: Allowing MM to remain on top?
    Feb 2005
    As part of my skin I am embedding MM into RR. I have removed all the menus / additional screens from MM and have done my own OSK for RR with an Application area for MM to sit in. However as the MM popup for the 'destination picker; doesn't have a window title I can't capture it and it has to sit above the MM application...
    Sooo.. Is there some way of allowing MM to keep the focus when I press on one of the RR OSK keys (which currently brings RR infront of MM).
    Or, alternatively am I going about this in the wrong way? Can I kick off the route planner in a different way and have it embed properly into RR?
    I know what I want to say in this post - but I'm not sure I've said it correctly. So if need be I will give futher clarification.
    Ta
    Ash
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    because of the Way MM is built you should most likely use MM's OSK and not RR's... nothing prevents you from trying to use "APPOSK" to send keys to MM though, the only requirement is that you disable the Embedding integration OR use "DETATCHMM" before calling "APPOSK" ..
    Ride Runner RR's Myspace
  1. MM not allowing shutdown
    By techy101 in forum Map Monkey
    Last Post: 10-11-2006, 04:03 PM
  2. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 03:02 PM
  3. CF 1.4 and MM 1.3.xxx
    By SOS in forum Centrafuse
    Last Post: 08-08-2005, 09:20 AM
  4. Problems with MM Advanced Mode/SiRF
    By RoyN in forum Map Monkey
    Last Post: 04-24-2005, 12:49 PM
  5. SENDKEY & MM Embedding
    By ruairi in forum Road Runner
    Last Post: 04-04-2005, 05:36 PM
