Results 11 to 20 of 21
Thread: Alternative Calculator
  1. #11
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Whew! Got my first app running from a button on the main menu!
    Now is there any way (other than messing with Skinbedder) that I can get rid of the menu bar that says "Help" from the applet?
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  2. #12
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    The Flash loader is compressed somehow so reshacker won't work on it. Just use the one tj posted (it doesn't have the help menu).
  3. #13
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Ok so for non RR user, how you kill the APP?
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  4. #14
    Raw Wave tj!2k4's Avatar
    Oct 2004
    ALT-F4, or right-click on the taskbar instance...
    You want me to recreate the .exe so that you can hit ESC?
    If you want, I can also add the standard Windows titlebar to teh app.
  5. #15
    Mar 2004
    Los Angeles Area
    Quote Originally Posted by thanatos106
    Thanatos.
    What's a non-RR user doing in this forum? If I wasn't using RR there are a lot of other better calculators out there to pick from.
  6. #16
    Oct 2004
    hey now, non-rr-user here too..
  7. #17
    FLAC djmickyg's Avatar
    Feb 2004
    Thanatos.
    the skin im using has a close button.. so i did bother finding a loader with a close button..
  8. #18
    Nov 2004
    Hello!!!! so you going to give me hard time cus I use other front end??
    bring it on then!!!!
    Thanatos.
    Edit:
    And so you know even guino change CDRip plugin to let non RR users use it.
    Nissan Aux-in MOD
  9. #19
    Mar 2004
    Los Angeles Area
    As soon as I hit the SUBMIT button I knew someone would probably take offense at my comment which was basically rhetorical and had no ill intent. Can't we all just lighten up?
  10. #20
    Nov 2004
    You know what! drop the BS cus you knew that the non RR user was me, so don't come with that "As soon as I hit the SUBMIT button I knew someone would probably take offense" cus it doesn't work.
    If you want to use you rhetorical stuff go to the newbie section and start posting there alright? (maybe they get scare but no me pal)
    So now that things are clear I ask TJ if he can mod the APP so it can have a off button (like changing "C" or "CE" for "OFF") just to bring the thread back to topic.
    Thanatos.
    Nissan Aux-in MOD
  1. Replies: 4
    Last Post: 10-24-2005, 08:45 AM
  2. Optional Alternative OSK Method - HOW ?
    By grnikolis in forum Map Monkey
    Last Post: 10-21-2005, 12:03 PM
  3. Calculator as input
    By cruiser01 in forum Input Devices
    Last Post: 09-21-2004, 11:30 AM
  4. Wi-Max : A viable alternative to Wi-Fi?
    By Maxis24 in forum Wireless Communications
    Last Post: 03-26-2004, 06:35 PM
  5. AUX input alternative
    By Pariah in forum General Hardware Discussion
    Last Post: 12-08-2003, 01:54 PM
