Results 1 to 3 of 3
Thread: Phoco, RR, Hematec
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Phoco, RR, Hematec
    Hematec, again thanks for your help.
    I decided to post a new thread as I didn't know if it was right in the other post of RR updates.
    What I am seeing is when I accept a phone call in RR is that the audio bridge isn't active, it just recycles the BT connection back to serial port communications.
    I added the below entries into phoco ini under general settings;
    ConnectHSP=1
    #BTDeviceName= NOTE: I added this and it didn't make a difference since the BT device was already active and seen.
    When a phoco standalone is running it takes almost 2 seconds for the BT audio bridge to be active after you accept a call and it drops the serial BT communications out. To hangup in phoco you must press the headset icon to disconnect and it recycles back to BT serial communications port (about 6 seconds). This was accomplished by adding the following line to the phoco (v. 1.5) under communication id section;
    <UseBTManager device="Motorola Phone" controlHeadset="True" disconnectAfterCall="True" mode="OnCall">True</UseBTManager>
    On a lot of motorola phones and some others, they only allow one BT connection at a time. So here's my problem.
    Now below are the log file entries from phoco, one with phoco as a standalone and the other with RR/Phoco.
    Phoco running standalone.....
    11/2/2005 12:36:12 PM Got CLIP over CLCC: ..<-----NOTE: MY INBOUND PHONE NUMBER shows up here....
    11/2/2005 12:36:12 PM Callers photo not found!
    11/2/2005 12:36:16 PM COM: >ATA
    11/2/2005 12:36:17 PM COM: <
    OK
    11/2/2005 12:36:17 PM Port closed by user!
    11/2/2005 12:36:19 PM Bluetooth headset on device 'Motorola Phone' connected! <--- here's is the 2 second delay
    11/2/2005 12:36:27 PM Port not open. Escalating timeout!
    11/2/2005 12:36:27 PM **** TIMEOUT ****
    11/2/2005 12:36:27 PM Opening COM10
    11/2/2005 12:36:28 PM COM: >ATZ
    11/2/2005 12:36:32 PM Opening COM10
    11/2/2005 12:36:35 PM **** TIMEOUT ****
    11/2/2005 12:36:35 PM COM: >ATE1
    11/2/2005 12:36:42 PM **** TIMEOUT ****
    11/2/2005 12:36:42 PM COM: >ATE1
    11/2/2005 12:36:49 PM **** TIMEOUT ****
    11/2/2005 12:36:50 PM COM: >AT+COPS?
    11/2/2005 12:36:57 PM **** TIMEOUT ****
    11/2/2005 12:36:57 PM COM: >AT+CGSN
    11/2/2005 12:37:04 PM **** TIMEOUT ****
    11/2/2005 12:37:04 PM COM: >AT+GMI
    11/2/2005 12:37:05 PM Bluetooth headset on device 'Motorola Phone' disconnected!
    11/2/2005 12:37:05 PM Opening COM10 <-------Recycle to BT com port here, 6 second delay ...
    11/2/2005 12:37:11 PM **** TIMEOUT ****
    11/2/2005 12:37:11 PM COM: >ATE1
    11/2/2005 12:37:11 PM COM: <
    OK
    Phoco running under RR and remote tags...
    11/2/2005 1:17:47 PM RemoteCommand: <PhoneControl.NET><BTConnectHSP device="Motorola Phone">True</BTConnectHSP></PhoneControl.NET>
    11/2/2005 1:17:47 PM COM: <
    +CRING: VOICE
    11/2/2005 1:17:49 PM COM: >AT+CLCC
    11/2/2005 1:17:49 PM Got CLIP over CLCC: <---- Again MY INBOUND PHONE NUMBER shows up here....
    11/2/2005 1:17:49 PM Callers photo not found!
    11/2/2005 1:17:53 PM COM: <
    +CRING: VOICE
    11/2/2005 1:17:56 PM RemoteCommand: <PhoneControl.NET><Accept/></PhoneControl.NET>
    11/2/2005 1:17:56 PM COM: >ATA
    11/2/2005 1:17:56 PM COM: <
    OK
    ---------------------------------------------------------------------------- <------ Audio bridge should have been here
    11/2/2005 1:18:06 PM COM: >AT+CLCC
    11/2/2005 1:18:07 PM COM: <
    +CLCC: 1,,0,0,0,"MY INBOUND PHONE NUMBER",129,<---- MY INBOUND PHONE NUMBER shows up here....
    OK
    11/2/2005 1:18:07 PM COM: >AT+CSQ;+CBC
    +CSQ: 27,99
    +CBC: 1,20
    OK
    11/2/2005 1:18:18 PM RemoteCommand: <PhoneControl.NET><Hangup/></PhoneControl.NET>
    11/2/2005 1:18:18 PM COM: >AT+CHUP
    11/2/2005 1:18:33 PM **** TIMEOUT ****
    11/2/2005 1:18:33 PM RemoteCommand: <PhoneControl.NET><BTConnectHSP device="Motorola Phone">False</BTConnectHSP></PhoneControl.NET>
    11/2/2005 1:18:47 PM COM: >AT+CLCC
    11/2/2005 1:18:47 PM COM: <
    ERROR
    11/2/2005 1:18:47 PM COM: >AT+CSQ;+CBC
    +CSQ: 27,99
    +CBC: 1,20
    OK
    11/2/2005 1:19:07 PM COM: >AT+CLCC
    11/2/2005 1:19:08 PM COM: <
    OK
    11/2/2005 1:19:08 PM COM: >AT+CSQ;+CBC
    +CSQ: 27,99
    +CBC: 1,20
    OK
    11/2/2005 1:19:28 PM COM: >AT+CLCC
    11/2/2005 1:19:28 PM COM: <
    OK
    11/2/2005 1:19:28 PM COM: >AT+CSQ;+CBC
    11/2/2005 1:19:29 PM COM: <
    +CSQ: 27,99
    +CBC: 1,20
    OK
    11/2/2005 1:19:49 PM COM: >AT+CLCC
    11/2/2005 1:19:49 PM COM: <
    OK
    11/2/2005 1:19:49 PM COM: >AT+CSQ;+CBC
    +CSQ: 27,99
    +CBC: 1,20
    OK
    <-----------Call terminated by hangup tag button in Phoco Skin of RR... no audio bridge
    Again, thanks for your help and if this is too much of a problem, then that's fine.
    Mar 2005
    Germany
    hi,
    i'll take a look at it as asap...
    Oct 2005
    Arkansas
    Thanks, Hematec!
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  2. Phoco not working in RR Win 2000, help...
    By couteau in forum Road Runner
    Last Post: 09-06-2005, 09:04 PM
  3. A cheat to integrate Phoco into RR or any Front Ends
    By couteau in forum PhoneControl
    Last Post: 09-06-2005, 10:46 AM
  4. Phoco and RR (again)
    By Enforcer in forum Road Runner
    Last Post: 08-03-2005, 09:32 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
