Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Phone button to bring Phoco in front of RR
  1. #11
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by -zip-
    Thanks liquid It is working .... sort of I don't think Phoco likes being handled this way. As long as you do not minimize Phoco you are ok. But once you do, it will not maximize again. I have asked Zorro if it is possible to create a button on the Phoco screen that will replace the minimize button in Phoco and add a Run=C:\programs\RoadRunner\Roadrunner.exe command to the button. .
    But the code is right. Thanks again!
    it works for me when phoco is minimized, only problem i havent ever been able to figure out is how to get rid of the button that shows up when you minimize phoco
    there is also a switch to window command in phoco, it works a little weird as in i think you cant shut phoco down, it has to be killed by another app.
    beer replenishment fund
    mp3car live search
  2. #12
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by liquid_smoke
    Set the button to false.. worked for me. He also got back to me about how to create a button to go back to RoadRunner
    From Zorro:
    Open the configuration file with Extended Configurator, then set PopupOnHide to False (MainWindow section).
    How to give the window back to RR:
    Have a look at WindowToSwitchTo : http://zhorvat.dyndns.org/PCForums/S...aspx?PostID=39
    Use "RoadRunner".
    Sound Stage
    Eclipse|MTX|Infinity
  3. #13
    Aug 2003
    Chicago
    From Zorro:
    Use "RoadRunner".
    ah, that works. I didnt know that button was called "PopupOnHide", i was trying to find it in the skineditor.
    mp3car live search
  4. #14
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by wfs1
    Out of curiosity, what enhancements are you getting out of doing it this away? If you run it remotely/embedded from RR what are the downsides??
    I have the single BT connection problem with Phoco/RR on a Motorola type phone but the rest of it is working fairly well.
    The TCP/IP remote calls on port 17xx can slow things down a bit on the CarPC when connected to a full LAN/WAN network and Internet.
    If you have Phoco running and want to use the Phone for a DUN, then that causes problems.
    Up to the last update of RR which I have not tried yet, was not able to use the headset function properly when using bluetooth and Phoco and RoadRunner, also the skin I was using did not have signal strength, or battery useage.
    With Phoco stand alone the headset automatically connects on in comming calls and will disconnect when done, or if I want to I can hit a button and headset is turned off and I can pickup the phone.
    I also like the fact that I can shutdown Phoco if needed but have RoadRunner still going or visa versa.
    Sound Stage
  5. #15
    FLAC -zip-'s Avatar
    Ontario/Canada
    No problem also, I needed to change
    Use Taskbar=true
    in Phoco now it responds EXACTLY as you said it would.
    Thanks Liquid for your help!
    Sound Stage
  1. Replies: 2
    Last Post: 04-04-2005, 03:45 PM
  2. Replace Phone button with other app
    By leckan in forum Centrafuse
    Last Post: 02-13-2005, 04:20 AM
  3. Replies: 7
    Last Post: 02-05-2005, 06:41 AM
  4. phone control button?
    By djtrickee in forum FrodoPlayer
    Last Post: 01-02-2005, 09:51 PM
  5. Routing power button to front of PC. Can wire be too thick of gauge?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 09-27-2003, 02:32 PM
