Results 1 to 10 of 15
Thread: Phone button to bring Phoco in front of RR
    FLAC -zip-'s Avatar
    Ontario/Canada
    Hi guys,
    I want to run RR and Phoco seperate as there are more features available with Phoco as a stand alone.
    All I need is when I push the Phone button in RR the already running but hidden Phoco pops up.
    I looked at the commands in the RR skin editor but cant figure it out.
    Sound Stage
    Eclipse|MTX|Infinity
    Raw Wave
    Jun 2004
    On the beach
    I think if you just set a RUN command it will pull the already open PhoneControl to the fore.
    FLAC -zip-'s Avatar
    Ontario/Canada
    "RUN;C:\Program Files\PhoneControl.NET"
    no workie
    Sound Stage
    Raw Wave
    Jun 2004
    On the beach
    You haven't got the exe on the end of that path.
    Low Bitrate DonkeyBoy's Avatar
    Mar 2005
    Stockport UK
    What happens when you are in RR and a call comes in. Will the phoneco popup show? Also how do you switch back to RR?
    Have been trying this out myself and have the problem that the popup is not shown above.
    Any suggestions ?
    VIA EPIA M10000 LVDS 1Ghz Motherboard,
    256Ram,80Gig,
    Lilliput 7" In Dash Touchscreen
    Panasonic Slimline Slot-in Cdrw/dvd Player,
    USB Gps Reciever,
    Belkin Bluetooth dongle
    Belkin USB wifi
    Carnetix CNX-P1290 60W Power Regulator
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by Gobby
    Even with .exe does not work.
    Sound Stage
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by DonkeyBoy
    Any suggestions ?
    Just need to find a way to push the Phone button in a RR skin and Phoco goes in front of RR to make a call. You can minimize phoco after you are done. There is a setting in Phoco for hidden when not in use and when it first starts up.
    Phoco will show when a call comes in no problems without the popup button
    Sound Stage
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    This command should run phoco and also bring it to front, remember to include the quotes.
    "RUN;C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe"
    also, since you guys are talking about this, how do you get rid of that button that shows up when you minimize phoco?
    beer replenishment fund
    mp3car live search
    FLAC -zip-'s Avatar
    Ontario/Canada
    Thanks liquid It is working .... sort of I don't think Phoco likes being handled this way. As long as you do not minimize Phoco you are ok. But once you do, it will not maximize again. I have asked Zorro if it is possible to create a button on the Phoco screen that will replace the minimize button in Phoco and add a Run=C:\programs\RoadRunner\Roadrunner.exe command to the button. .
    But the code is right. Thanks again!
    Sound Stage
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Out of curiosity, what enhancements are you getting out of doing it this away? If you run it remotely/embedded from RR what are the downsides??
    I have the single BT connection problem with Phoco/RR on a Motorola type phone but the rest of it is working fairly well.
    The TCP/IP remote calls on port 17xx can slow things down a bit on the CarPC when connected to a full LAN/WAN network and Internet.
    If you have Phoco running and want to use the Phone for a DUN, then that causes problems.
  1. Replies: 2
    Last Post: 04-04-2005, 04:45 PM
  2. Replace Phone button with other app
    By leckan in forum Centrafuse
    Last Post: 02-13-2005, 05:20 AM
  3. Replies: 7
    Last Post: 02-05-2005, 07:41 AM
  4. phone control button?
    By djtrickee in forum FrodoPlayer
    Last Post: 01-02-2005, 10:51 PM
  5. Routing power button to front of PC. Can wire be too thick of gauge?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 09-27-2003, 03:32 PM
