Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Is there a way to disable RoadRunner splashscreen
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    during program launch?
    Mar 2005
    Czech republic
    Got it, thanks.
    Nov 2005
    I read this=
    -There's a "loading banner" now -- I guarantee you that it will not slow down the start process in any way, but it will tell you what's going on. I did this so I could discard unused code from memory after loading, plus, give some user feedback. You can disable the Loader using the (Quiet) command line parameter: /Q
    I don't understand it though, where would I put the /Q
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    The shortcut you use to launch it.
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Nov 2005
    I put in "C:\Program Files\Road Runner\RR.exe"/Q in my shortcut and windows gives me
    The name "'"C:\Program Files\Road Runner\RR.exe"/Q' specified in the target box is not valid. Make sure the path and file name are correct.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    "C:\Program Files\Road Runner\RR.exe"/Q is wrong....
    it should be
    "C:\Program Files\Road Runner\RR.exe /Q" (notce the space between exe and /Q
    Roy
    2005 Range Rover 4.4
    São Paulo, Brazil
    ps: test it out using the Start->Run option
    Roy
    Nov 2005
    that gives the same error, also when I try it from run
    C:\Program Files\Road Runner\RR.exe will work but
    C:\Program Files\Road Runner\RR.exe /Q will not work
    Sep 2005
    San Luis Obispo, CA
    Yup, need switch options w/i the quotes.
    -arebelspy
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 05:41 AM
  2. Super small XP install
    By knubile in forum WinNT Based
    Last Post: 04-26-2008, 02:44 PM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
  4. nLite and USB Devices
    By Nobias in forum WinNT Based
    Last Post: 01-20-2005, 10:11 PM
  5. nLite making me nSane: Frodoplayer issue
    Last Post: 01-13-2005, 12:09 AM
