Results 1 to 5 of 5
Thread: RoadRunner and Freedrive at Startup
    Sep 2005
    UK
    Like some I am using RoadRunner with Freedrive as my GPS software.
    I am not realy having an issue but there isn't a little anoyance I would like to try and resolve.
    My current setup is such that RR.exe is started as my windows shell from the registry. Freedrive is then run from the rr.ini.
    The issue I am having is that roadrunner start and i use a cool new roadrunner splash screen, then after the splashscreen disapears the freedrive splash screen apears (which I understand is going to be hiddable in the next release for freedrive) after the freedrive splash screen disapears freedrive opens up for about 3 seconds or so before going back to the roadrunner main menu.
    Is there anyway to prevent this by either getting Freedrive to load in the background or is there an always on top setting for road runner? I have tried loading freedrive minimized (set at the freedrive ini) but it still breaks up the loading sequence of road runner.
    Thanks in advance for any help
    Chris
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    tried using RUNQ instead of RUN in rr.ini?
    Sep 2005
    UK
    yeh, actually my original post was a miss type i meant runq. I even tried runqw, run and runw.
    Sep 2005
    UK
    awsome. thanks enforcer. Only thing I will mention if anyone else has this problem is to make sure the freedrive state in the freedrive config is set to normal.
  1. Freedrive SDK in RR label
    By LagunaICE in forum Road Runner
    Last Post: 11-12-2005, 02:24 PM
  2. freedrive, roadrunner, frodoplayer help
    By blacura1996 in forum Newbie
    Last Post: 10-01-2005, 08:50 AM
  3. Auto Load Freedrive ???
    By tolisn in forum FreeDrive
    Last Post: 07-08-2005, 05:50 PM
  4. Release FreeDrive 0.70 Full
    By CdRsKuLL in forum FreeDrive
    Last Post: 06-29-2005, 05:01 PM
  5. Display labels from FreeDrive
    By CdRsKuLL in forum Road Runner
    Last Post: 04-09-2005, 01:40 AM
