Page 10 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 91 to 100 of 170
Thread: Released: BETA 10
  1. #91
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by skippy76
    This is the last post I have to say on this before I get back to working on productive stuff, I'm a brit living in the US.
    I must admit I thought you where from Oz hence the user name Skippy76 ( 76 as in the year you where born ).
    But that been said your comments are true where ever you come from...
    Terran
  2. #92
    May 2005
    Germany
    Hi,
    I made some screenshots to show my problem with the indicators.
    Position of the LED: 126,538,12,12
    Position of mute Button: 424,534,115,50
    My skin.ini:
    I05,25,465,115,50,"REPEAT:b"
    I06,424,534,93,50,"MASTERMUTE:b"
    I02,124,536,16,16,"GPSVOL:b"
    The Problem is, that the LED is always on, no matter if GPSVOL is deactivated in RR.config or no GPS signal.
  3. #93
    Jan 2003
    Quote Originally Posted by Ti-ejtsch
    Hi,
    My skin.ini:
    Cant you refer to an empty skin like some of the older ones used ?
    Terran
  4. #94
    May 2005
    Germany
    Hi,
    what do you mean, my english is terrible, sorry, sorry, sorry
  5. #95
    Jan 2003
    Hi,
    Look at some of the orginal Media Car skins... sorry - I'm really bad explaining, its not u.
    Terran
  6. #96
    tim
    tim is offline
    Sep 2005
    Finland
    Quote Originally Posted by RoyN
    hmm skippy, it seems that posting here fixed the problem...
    can you explain please what the exact function of the 2 settings in RR config is? one is for max %, which I imagine is the maximum change allowed to the user-specified volume, and the other setting is the % at 80kph, which I imagine is that every 80kph, it would add x% to the volume?
    I think I should respond to that because these are the changes what I added
    to skippys code as third different speed mode option.
    At first if someone is really interested how this is working and why I like to add another different mode, it's good to read this page:
    Setvol and Speed Attenuated Volume Control
    But, shortly idea was:
    - User can change volume normally with volume buttons at any time
    - Only the gain which will compress noise coming from speed is changed.
    Of course this gain is then added to master volume automatically, so what user can see and hear is that master volume is changing when speed change.
    max step % is maximum value how much volume is changed per second in any situation. Setting this to small you can make changes to smoother, setting to 100 will ignore this funtionality totally. This value is now used for every mode and it's functionality is some for all of them.
    Gain vol % at 50 mph is volume which is added to your current volume in 50 mph speed. Depending from this value, correct gain is calculated for your current speed [(speed / 50) * gainat50mph], so at 25 mph only half from this value is added as gain to master volume.
    Here is also very simplifyed example:
    max step % = 0.5%
    Gain at 50mph = 7
    User set volume to 10% at 0 mph speed
    Speed change to 20 mph
    -> Calculated new volume = 12.8 [10 + (20 / 50) * 7]
    But because max step is 0.5, volume start to change only by 0.5% steps / second.
    after 1 second volume is: 10.5
    after 2 second volume is: 11
    after 3 second volume is: 11.5
    after 4 second volume is: 12
    after 5 second volume is: 12.5
    after 6 second volume is: 12.8
    Hope this explain.
    Tim
  7. #97
    May 2005
    Germany
    Hi,
    I tested it with the original RR-BMV.skin. Same problem!
    Is there a skin with GPSVOL intecrated?
    Ti-ejtsch
  8. #98
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    @upscale, I couldnt care less about iguidance, so it is just a FEW users who would benefit.... you should measure your comments cause if THAT MANY users saw this as a critical part, someone would have done more work...
    I use freedrive and cdr (freedrive developer) is always adapting freedrive to work better with frontends, and frontend writers are adapting rontend to work best with FD....anyways, enough said out of the topic...
    ti-ejtsch, what do you mean? GPSVOL is independent of the skin, it works on all skins afaik...
    Roy
    2005 Range Rover 4.4
  9. #99
    May 2005
    Germany
    I mean the indicators to show, if GPSVOL is activated by pressing the mute button or not.
    Ti-ejtsch
  10. #100
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I've noticed that for somereason RR is saying ASCII or something when it starts. This could be a problem I introduced when I merged Guino's and my code. Shall take a look.
    Mine is talking now – it started when I put a start night time in and now the only way to turn it off is to not use built in gamma – gps or other
    Edit - you can turn it off by hitting the gamma button
    2001 S10 ZR2
    Chucks Skin - to old
  1. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 11:29 PM
  2. MediaEngine Beta 2 Released!
    By phat_bastard in forum Media Engine
    Last Post: 09-20-2005, 09:53 AM
  3. FrodoPlayer 1.0.3 Beta Has Been released.
    By frodobaggins in forum FrodoPlayer
    Last Post: 04-23-2004, 04:37 PM
  4. beta plug-in update, 2.03 has be released
    By Blackwind in forum Software & Software Development
    Last Post: 02-19-2001, 09:15 PM
  5. Blackwind's keypad plugin v2.0 beta released
    Last Post: 02-11-2001, 04:54 AM
