Page 11 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 101 to 110 of 170
Thread: Released: BETA 10
  1. #101
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Just added "PLAYLISTCOUNT" to my skin and it does not work with beta 11 – works with RR 11-27-05
    2001 S10 ZR2
    Chucks Skin - to old
  2. #102
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    from my understanding, skippy was going to send the hanges he did, since guino hadnt released 11-27 sources...
    i might be off though, sicne im a bit behind on my reading
    Roy
    2005 Range Rover 4.4
  3. #103
    São Paulo, Brazil
    what same seller? I dont quite remember who i got it from, it was about 1.5yrs ago...
    Roy
  4. #104
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    wow, ok... so there have been many changes to the source. This will be made available once we have released the changes that are in these BETAs.
    Ok, regarding the indicators. Ti-ejtsch: Please can you email me a zip of your skin so that I can test with it. Others have already tested this and it worked...
    Chuck: Regarding PLAYLISTCOUNT: I shall take a look.
    Tim: ARe you changing the code at all or can I go ahead and make changes?
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  5. #105
    Mar 2004
    Cambridge, MA, USA
    Ok, here's an update:
    Chuck: Regarding PLAYLISTCOUNT, the code is in there and has not changed so I'm not sure at present why this is not working.
    Tim: I'm going to be releasing a BETA 11b. I shall provide you with the updated code as I think there are some changes you wanted to make.
    Everyone: I shall release BETA 11b shortly. There are two major bugs that I've fixed:
    - If the Gamma offset is set to 0 a divide by zero error occurs. This is why some have reported that the Auto GAmma is not working!
    - The second problem is that when you have a night skin configured and you are using Auto GAmma it should change to the night skin. However, this previously did not work (RR repeated 'ightski' to you... emmm)
    Thanks,
    Andrew
    06 Volvo XC90
  6. #106
    Mar 2004
    Cambridge, MA, USA
    So, here is BETA 11b..
    LOTS of nice changes:
    - 3 stage gamma button (configurable through RRConfig)
    - 3 stage skin button (configurable through RRConfig)
    - fixed divide by zero problem
    - added gpsskin indicator too (as well as gpsgamma indicator)
    - Moved all skin / gamma settings to seperate window in RRConfig
    - Added shufflevideo option (button / indicator)...
    Big thanks to Chuck for working on the testing with me. We have done quite a lot so think that most if not all should be good now!
    The only bug I know of is if you specify the gamma day time to be later than the night time...
    06 Volvo XC90
  7. #107
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    When will you let me "review" the sources ?
    Ride Runner RR's Myspace
  8. #108
    Mar 2004
    Cambridge, MA, USA
    Guino, for you man... whenever you like. I think we have got rid of most of the bugs. I want to double check that everyone is happy, and if so I'll pass them over to you. I did not want to do it too soon and end up having to make more changes!
    06 Volvo XC90
  9. #109
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by RoyN
    Also, is there anything special that needs to be done for gps gamma to work? Testing the gamma through the button shows me day/night gamma, but gps gamma is on, offset=0, and still no dimming at night.... any idea? (Im probably missing something really stupid... Ill try time-based today)
    i dont think mine is working either.. havent had a big play with it but it doesnt seem to me..
    also, will RR make Freedrive switch to day and night?? and also will it record the last LAT & LOG so next time RR is started it will dim/brighten the screen before the gps software has opened??
  10. #110
    Mar 2004
    Cambridge, MA, USA
    djmickyg... nice ideas... Have you tried BETA 11b? I fixed a few major issues with the Auto Gamma / Skin stuff...
    06 Volvo XC90
  1. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 10:29 PM
  2. MediaEngine Beta 2 Released!
    By phat_bastard in forum Media Engine
    Last Post: 09-20-2005, 08:53 AM
  3. FrodoPlayer 1.0.3 Beta Has Been released.
    By frodobaggins in forum FrodoPlayer
    Last Post: 04-23-2004, 03:37 PM
  4. beta plug-in update, 2.03 has be released
    By Blackwind in forum Software & Software Development
    Last Post: 02-19-2001, 08:15 PM
  5. Blackwind's keypad plugin v2.0 beta released
    Last Post: 02-11-2001, 03:54 AM
