Page 12 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 111 to 120 of 170
Thread: Released: BETA 10
  1. #111
    FLAC djmickyg's Avatar
    Feb 2004
    i think i have the latest
    i will check now
    edit: igot the one that came out on the 27th
    i am redownloading anyways
  2. #112
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    unless you downloaded it in the last 20 mins you don't have the latest.
    [Edit] BTW, in the previous version if your offset was set to zero ( 0 ) then the gamma change would not work. I actually had a device by zero (d'oh)... but I've resolved that issue now, so you should be good in BETA 11b.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  3. #113
    Feb 2004
    ok ive just downloaded it now
    thanks.. i will have a play with this one
    EDIT: all works good now.. i like alot
  4. #114
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Well I tried out the auto-skin change in the new beta version (11b).It seem that the auto-skin change is directly linked to the auto-gamma selection. If you want auto-skin changing then you also have to select auto-gamma change in the config. utility. If only auto-skin change is selected and auto-gamma is set to disable then the skin will not change automatically. This observation was made without using a GPS (time based auto switching). Is this a normal behavior?
    The road is long but we are getting there.
  5. #115
    Dec 2003
    Greece
    Quote Originally Posted by skippy76
    So, here is BETA 11b..
    LOTS of nice changes:
    - 3 stage gamma button (configurable through RRConfig)
    - 3 stage skin button (configurable through RRConfig)
    - fixed divide by zero problem
    - added gpsskin indicator too (as well as gpsgamma indicator)
    - Moved all skin / gamma settings to seperate window in RRConfig
    - Added shufflevideo option (button / indicator)...
    Big thanks to Chuck for working on the testing with me. We have done quite a lot so think that most if not all should be good now!
    The only bug I know of is if you specify the gamma day time to be later than the night time...
    What is the button code for the 3stage skin button ? I've searched the skin commands.txt file but I cannot find it. Is it one of the old button or is it a new addition ?
  6. #116
    Feb 2004
    Quote Originally Posted by tolisn
    i believe its the old button, it now has 3 positions so.. dark/light/auto
  7. #117
    Mar 2004
    Cambridge, MA, USA
    Yes,
    for skin it's daynightskin
    for gamma it's gamma
    tolisn: Actually, small oversight on my behalf. I've fixed the bug and BETA 11c will be there in about 20 mins.
    [Edit]: It's just uploading... I've also added a command daynightgammaskin this button will change the state of both the gamma and the skin.
    06 Volvo XC90
  8. #118
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I think I found a bug in RR
    Before if you use the RUN command in a button (RUN:C:\test\test.exe) and the exe file was not found it would ignore it and go on. But with new RR it will stop RR from running on my machine.
    Button for truck and not on desktop
    B33,162,394,150,63,"SHOWWINDOW;!Shell_TrayWnd;True ||RUN;C:\WINNT\TRTUTILS\TRTUTILS.EXE||SWITCHBUTTON ;1>>SHOWWINDOW;!Shell_TrayWnd;FALSE||CLOSEWINDOW;T ouchRight Utilities||SWITCHBUTTON;1",""
    2001 S10 ZR2
    Chucks Skin - to old
  9. #119
    Mar 2004
    Cambridge, MA, USA
    Chuck: This maybe something that Guino introduced. Can you try it with the latest release that Guino sent out?
    06 Volvo XC90
  10. #120
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Same with RR 11-27-05
    will post in 11-27-update
    2001 S10 ZR2
  1. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 11:29 PM
  2. MediaEngine Beta 2 Released!
    By phat_bastard in forum Media Engine
    Last Post: 09-20-2005, 09:53 AM
  3. FrodoPlayer 1.0.3 Beta Has Been released.
    By frodobaggins in forum FrodoPlayer
    Last Post: 04-23-2004, 04:37 PM
  4. beta plug-in update, 2.03 has be released
    By Blackwind in forum Software & Software Development
    Last Post: 02-19-2001, 09:15 PM
  5. Blackwind's keypad plugin v2.0 beta released
    Last Post: 02-11-2001, 04:54 AM
