Page 14 of 17 FirstFirst ... 4567891011121314151617 LastLast
Results 131 to 140 of 170
Thread: Released: BETA 10
  1. #131
    FLAC mauri's Avatar
    Jan 2004
    @Skippy
    Thanks for you fast PM reply
    All OK !
    Mauri
  2. #132
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Quote Originally Posted by skippy76
    tolisn: Do you have some code in VB that already does this? If you know any VB then feel free to knock up a very simple app then I shall integrate into RR for you.
    Saves me a lot of time and also get's your request done faster...
    I would love to help out on this great and ever expanding project but unfortunately I do not have any coding skills. After having a second though about this parallel port request It looks to me that we should ditch the parallel port implementation and focus on better integration and full support of the phidget 8/8/8 module. It would be the best choice because many people around the board have these and it will also be a waist of coding time since the phidget board has already been supported to some extent.
    I would like to thank you for your time and effort to support and fulfill every request that we make. Thanks a million
    The road is long but we are getting there.
  3. #133
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    No problem. I'm pleased that:
    a) You've taken the time to let me know so that I don't waste my time.
    b) You've decided that the Phidget board is the best way to go, as it its!
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  4. #134
    Low Bitrate MoonShiner's Avatar
    Westminster, CA
    shufflevideo command
    Skippy,
    I'm trying to test the shufflevideo command, is it working? I can't seem to get the videos to shuffle. I'm using the internal video player (I assume it's media player classic).
    Also, which line in resume.ini refers to the videoshuffle?
    Any help is appreciated.
    Thanks!
  5. #135
    Jul 2005
    Birmingham,UK
    Skippy, tolisn. I raised the parallel port idea a while ago and it did receive some interest. Since then I've started to put some VB code together myself to do this. I'm no programmer so it's not pretty so forgive it's crudeness, well the parts that i created aren't but the examples I borrowed from Guino are, thanks Guino :-). Anyway if you or anyone else wants to finish it and develop it further I would be delighted and so have attached the source code here. All I would ask is that anyones efforts are made available to everyone to take advantage of. It actually uses the SDK to interface to RR and uses a dll I found freely available on the Web so I hope I'm not infringing any copyright by including it here. I haven't worked on it for a while and I can't even remember what state its in but it did work. Unfortunately I have to finish building the car first before implementing the carPC so this isn't high priority. Hope someone can find the time to develop it so it can realise its full potential.
    Attached Files Attached Files
  6. #136
    Mar 2004
    Cambridge, MA, USA
    Yep, I presume it's MP, but that should be independent to the implementation.
    Re Resume.ini: It should be the last line, I think like 8. Did you download the latest BETA from http://carpc.harteveldt.com
    06 Volvo XC90
  7. #137
    Mar 2004
    Cambridge, MA, USA
    p1cass0: I'll keep a note of this and take a look when I get round to it.
    Andrew
    06 Volvo XC90
  8. #138
    Westminster, CA
    I just downloaded the beta today, I think it's 11c. The last line in my resume.ini (line 6) is set to 0. Not sure why it's not shuffling though. I'm able to get the shuffle button and shuffle indicator to work (by work I mean when i click on the shufflevideo button, the shuffle indicator changes), but the videos continue to play in alpha order. Do I need to create a playlist or something?
  9. #139
    Mar 2004
    Cambridge, MA, USA
    Emmm, no... I basically wrote a proc that randomizes the files in the list. When you go into RRConfig / Video... What is Shuffle set to?
    06 Volvo XC90
  10. #140
    Westminster, CA
    I tried, ON, OFF, LAST....
    I applied the 11c beta to another backup copy I have of RR (build date was 10/31/05) and when first going into videos the list was randomized, but then I couldn't get it sorted back to alpha...
    I'll keep messing with it to see if it's something I'm doing.
    Thanks for all your help.
  1. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 11:29 PM
  2. MediaEngine Beta 2 Released!
    By phat_bastard in forum Media Engine
    Last Post: 09-20-2005, 09:53 AM
  3. FrodoPlayer 1.0.3 Beta Has Been released.
    By frodobaggins in forum FrodoPlayer
    Last Post: 04-23-2004, 04:37 PM
  4. beta plug-in update, 2.03 has be released
    By Blackwind in forum Software & Software Development
    Last Post: 02-19-2001, 09:15 PM
  5. Blackwind's keypad plugin v2.0 beta released
    Last Post: 02-11-2001, 04:54 AM
