Hello,
how can I see the indicators? What to do with the skin?
Ti-ejtsch
Indicators working
Hello,
Ti-ejtsch
You need to put some jpg files in your skin folder and add some stuff to your skin files
samples
My speed indicators in the skin
/, I, x, y, w, h, Code;INDICATORCODES
I60,9,535,10,10,"GPSVOL"
IMG,11,539,4,4,"LED.jpg",ON
My gamma indicators in the skin
I69,268,292,20,20,"GPSGAMMA:b"
IMG,273,297,12,12,"gamma.jpg",ON
IMG,273,297,12,12,"gamma off.jpg",OFF
Leds jpg files
Hi,
Thanks a lot. It´s working.
Another idea:
red LED: GPSVOL is activated but no GPS signal
green LED: GPSVOL is activated with GPS signal
Would this be possible?
Ti-ejtsch
Thanks. Firstly, I did point out that this is a BETA so was not going go into great detail about how the functionality works. To most I believe it is pretty self explanatory.
Re Gamma test button: I'll try to add this, should not be too difficult.
Re Transparent Flash: Does anyone else have this problem.
Re GPSVOL and now GPS fix: I'll see if I can also encorporate it into the same indicator.
Basically for those that don't quite understand what this release is... It's a BETA release. It's a pre-release... It's a "may work / may not work, please test".
Once everyone is happy with the functionality and that it works the way we want it to, this will become an official RR release. Why am I doing this?
a) It's open source
b) Guino is taking a little time out
c) People wanted the functionality I implemented so I went ahead and did it.
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
Skippy76 I will be going out in about 1 hour to test and will let you know how it went
Hi,
I understand!
But I have a problem with the indicators. When GPSVOL is activated I can see the LED (mute button 1) When I press the button once again GPSVOL should be deactivated but I can see the LED. Do I understand something wrong or is it correct?
Bug report here:
built-in auto Gamma day/night change does not work at all. Gamma change works fine if initiated manually from skin file (button press even) but not automatically based on time change.
If you put your indicator inside a button you will need to make it blink by adding a b in the code.
"GPSGAMMA:b"
"GPSVOL:b"
Just spotted a bug. For GPS Gamma it has to apply your time zone... I added the manual day / night time stuff to that functionality. A slight oversite on my befhalf as the times you specifiy appear to have the time offset also applied to them (again). I'll fix and release in BETA 10a (in about an hour or so).
Originally Posted by LagunaICE
06 Volvo XC90
