Page 5 of 17 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 170
Thread: Released: BETA 10
  1. #41
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Just got back from long test drive and down loaded beta 10A on the road
    Speed vol works good with linear – tried the others but at 70 mph the vol was all the way up and the slider made no change
    As for the gamma the button goes thru all modes with no problems in gps mode
    Now for transparencys with .swf files and windows 2000 – the background shows up now and it did not before like the picture of the clock in post #22 above.
    Did the indicators make this happen?
    2001 S10 ZR2
    Chucks Skin - to old
  2. #42
    was Boston -> now Canada!
    Else
    sRegKeyTZI = "Software\Microsoft\Windows\CurrentVersion\Tim e Zones"
    End If
    Is there a space there? Not sure if that is a typo in Time Zones or just the way it is being displayed in the post.
    Oh and here also a space after the T:
    sCurZone = GetRegValueStr("System\CurrentControlSet\Control\T imeZoneInformation", "StandardName")
    Just grasping at straws here :-)
    Chuck
  3. #43
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Thanks Chuck. Need to look into the other GPS Vol changes, not sure if Tim's changes has effected this.
    Not sure about the swf transparency problem! I'm using Windows Vista to compile on so it could have been something to do with that... (maybe / maybe not)...
    Tim is looking at the source code and is going to make some small fixes. Once he's done I'll issue BETA 10b
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  4. #44
    Internal GAMMA based on set times is working flawlessly for me :-) I was changing skins before but I'm going to try this as my default now.
    Thanks for the hard work.
    Chuck
  5. #45
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by skippy76
    did you use Vista to compile 9a?
    2001 S10 ZR2
  6. #46
    Gamma was working on my PC so I went to setup in the car. With the new RRCONFIG I get an error ONLY when trying to go into general settings. The following comes up COMCTL32.OCX is not registered or one of it's dependencies is missing.
    All other setting options appear to be working fine.
    Thx,
    Chuck
  7. #47
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    Yup, I found this "dependancy" too. Issue confirmed.
  8. #48
    Mar 2004
    Cambridge, MA, USA
    Chuck: Yes, 9a was compiled in Vista.
    Also I've checked the code and the spaces are not there... I think it's the way it is displayed here.
    Re dependency, yes, the ocx needs to be registred or copied to the Road Runner directory. I just copied over the ocx from my desktop to my carpc. In the next BETA release I'll put it in the ZIP file.
    06 Volvo XC90
  9. #49
    May 2005
    Germany
    Hi,
    I spend a lot of time for the indicators now, but it won´t work like I want. Something going wrong. Look at my skin.ini:
    /, I, x, y, w, h, Code;INDICATORCODES
    I05,25,465,115,50,"REPEAT:b"
    I06,424,534,93,50,"MASTERMUTE:b"
    I02,522,555,12,12,"GPSVOL:b"
    IMG,522,555,12,12,"LED.jpg",ON
    The LED.jpg is in the skin folder. Have I change something in my Skin.jpg.
    The problem:
    Press mute button -> mute is activated, no led
    Press mute button -> mute is deactivated, led is on but when I get over another button -> no led
    Press mute button -> same as second
    Ti-ejtsch
  10. #50
    FLAC djmickyg's Avatar
    Feb 2004
    the config looks nice..
    havent tried it in the car with gps yet but all is working on the home pc
    now rr is using gps cords for a few things now would it be wise to have the option for rr to conect to a port to get its own data. cus i dont run Freedrive all the time.. but i run a gps port splitter..
    or, the option for run gps in the background when RR is loading??
    anyways so far so good.. i will play some more
  1. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 11:29 PM
  2. MediaEngine Beta 2 Released!
    By phat_bastard in forum Media Engine
    Last Post: 09-20-2005, 09:53 AM
  3. FrodoPlayer 1.0.3 Beta Has Been released.
    By frodobaggins in forum FrodoPlayer
    Last Post: 04-23-2004, 04:37 PM
  4. beta plug-in update, 2.03 has be released
    By Blackwind in forum Software & Software Development
    Last Post: 02-19-2001, 09:15 PM
  5. Blackwind's keypad plugin v2.0 beta released
    Last Post: 02-11-2001, 04:54 AM
