Page 8 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 71 to 80 of 170
Thread: Released: BETA 10
  1. #71
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Right, here goes...
    I've released BETA 11 and it's available via the website:
    http://carpc.harteveldt.com
    Changes in this BETA include:
    - Merged Giuno's changes in... there were quite a few and it gave me a head ache in ensuring I did not miss out anyones changes... hopefully it's good!
    - Added a single kph / mph option to RRConfig and removed the exisiting one in GPS Vol and also in the GPS settings page. RR will now use this single value for all functionality that makes use of kph / mph.
    - Included the missing ocx in the zip file.
    Please ensure you run RRConfig and check all your config values (especially the kph / mph setting).
    Andrew
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  2. #72
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    on it now
    2001 S10 ZR2
    Chucks Skin - to old
  3. #73
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Hey Skippy76 and others...
    first of all thanks for your effort.... now, I just installed last night your 10a version (so still havent tried beta11 but I dont see your changelog referring to this), when using the USE VOLUME+ATTENUATION option, I'm having some problems...
    it seems that RR loves starting with volume at 0%...(when stopped - when I'm running volume starts at a bit, but when I stop goes to 0, showing that RR isnt really regarding the previous volume I had set)... Also, when I set volume to say 5%... I speed up, volume goes to 10%, then I stop, volume goes below 5%, to something like 3%, for example... if I speed up and slow down several times, eventually it will go to 0% when I stop, again disregarding my initial volume...
    I tried setting the max% and % at 80kph from 10% to 5% to see if it would do something, but it didnt change this behaviour...
    I have also noticed that often RR is stopped, not resuming when coming out of hibernation/restart... is the functionality broken?
    Overall the feature is great, but a bit unstable atmo... are you others having the same?
    Roy
    2005 Range Rover 4.4
  4. #74
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Beta 11 has introduced the transparencies with swf files on windows 2000 again.
    I just do not understand adding gps speed vol, gps gamma and indicators and so on would do this to RR 11-27-05.
    So I guess it back 9a or RR 11-27-05 for me in my truck till a fix comes out.
    2001 S10 ZR2
  5. #75
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    RoyN did you try the linear mode of speed vol?
    2001 S10 ZR2
  6. #76
    Mar 2004
    Cambridge, MA, USA
    RoyN: we need at least your RR.ini posted...
    Chuck: Niether do I! I'm looking into it.
    [Edit]: Can someone with the transparency problem please try installing the latest verison from shockwave? Between 9 and 9a (or around the time of 9) I installed Vista and also installed the latest version of Flash...
    I this the problem 'may' be due to that fact that I am compiling against the latest version of flash... Just a thought... I'm also looking into the code at the same time...
    [EDIT 2]: Ok, it's because I have the new version of flash installed. Therefore, if you have issues with Flash transparency, please go and download / install the new version of flash player:
    http://www.macromedia.com/shockwave/...ShockwaveFlash
    REMEMBER to untick the 'Install Yahoo toolbar'... unless you want the really annoying Yahoo toolbar that is...
    Also, apparently you need IE to download and install the Flash player.
    I've noticed that for somereason RR is saying ASCII or something when it starts. This could be a problem I introduced when I merged Guino's and my code. Shall take a look.
    06 Volvo XC90
  7. #77
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Good news
    The flash player was the problem on windows 2000 machine – thanks skippy76
    Now tomorrow I will test out everything I can (4:30 am)
    2001 S10 ZR2
  8. #78
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    no application transparency issues with 11a. THANK YOU!
  9. #79
    Mar 2004
    Cambridge, MA, USA
    excellent, was that after upgrading your flash player???
    Also, is anyone getting the same problem as me with BETA 11? It keeps saying something over and over again.
    06 Volvo XC90
  10. #80
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    Hey i was wondering if there is any chance if you could implment the shuffle in video player?
    thanks
    [|||||-----] 95% complete
  1. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 11:29 PM
  2. MediaEngine Beta 2 Released!
    By phat_bastard in forum Media Engine
    Last Post: 09-20-2005, 09:53 AM
  3. FrodoPlayer 1.0.3 Beta Has Been released.
    By frodobaggins in forum FrodoPlayer
    Last Post: 04-23-2004, 04:37 PM
  4. beta plug-in update, 2.03 has be released
    By Blackwind in forum Software & Software Development
    Last Post: 02-19-2001, 09:15 PM
  5. Blackwind's keypad plugin v2.0 beta released
    Last Post: 02-11-2001, 04:54 AM
