Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Phidgets 8/8/8 in RR
  1. #21
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    I agree. This can be done in the getindicator functionality.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  2. #22
    Oct 2003
    Copenhagen, Denmark
    Well, i was trying to use as little cpu cycles as possible, and it seems to me that checking the input every time GetIndicator runs would take quite a bit more time than letting the event function of the phidgets trigger a small piece of code only when something does change, and then only checking a true/false expression in getindicator would be less cpu intensive. This might seem a bit overkill, but i would hate to add to the sluggishness of the application in the long run (not that it is slow as such right now :-)
    Jan
    Not doing carpc anymore
  3. #23
    Oct 2003
    Copenhagen, Denmark
    foh, i think i was a little hasty in saying that it worked with my pg amps :-( seems i had it hooked up wrong somehow, after researching i must have been making a connection between ground and the inputs, reading the manual of the phidgets states :
    8 Digital Inputs
    Switch triggered - The digital inputs require only closing the inputs to the ground terminal via a switch, button, etc. No voltage should be used. The refresh rate is 125Hz for the Digital Input.
    doooh, now i have to figure out a little transistor on each output of my amp or a little relay or something....
  4. #24
    Oct 2003
    Copenhagen, Denmark
    Seems that the 0/16/16 works the way i was expecting the 8/8/8 to do, by applying a voltage to the input between 4 and 30vdc. i will have to measure the pg output before purchasing this one i think.
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
