Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Radio and RR
  1. #11
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Hi Guino, i intend to do a bit more testing to clear this up but as far as i can tell,nothing changed during the swap(using the standard car antenna).all that changed was the software. As for the plugs,yeah i had to use a bit of wire on an RCA jack for the D-Link,but no changes were made that could of affected the Wintv.
    I'm hoping at the end of all this there might be a solution for those suffering the wintv's lousy reception (the difference was startling).
    Thanks for the reply Guino, keep up the great work mate.
  2. #12
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    Is the Dlink DRU-R100 still for sale? I can't find a single online vender that sells them
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
  3. #13
    Nov 2005
    Midlands
    I don't think they make them anymore but there readily available on ebay for anything from £2 to £20,if your not bothered about RDS info its the 1 to go for.....Need RDS?....get a cinergy 600 mate.
    If you go for the D-Link don't use the standard driver(its got issues),
    use the 1 i posted above.
  4. #14
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    Dragged this up from an old post of mine. Got mine from here. Dunno if they still sell em.
    http://www.scan.co.uk/Products/Produ...roductID=20953
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
  5. #15
    Nov 2005
    Midlands
    Quote Originally Posted by guino
    The drivers should not matter... My guess is the way you mounted the antenna, and knowing that the plugs are different, I assume something changed there.. even if just the plug.
    you were right mate,it turns out that if mic boost is enabled your radio will sound rubbish,i found this out after a reinstall,the radio was awful again so i tried everything i could think of,after all that a simple tick box resolved the issue.
  6. #16
    Registered User Lava's Avatar
    May 2006
    Buffalo, NY
    Whats a good USB radio to use with RR that has RDS?
  7. #17
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    For all I know, Only the HQCT radio is USB and has RDS support.
    Ride Runner RR's Myspace
  8. #18
    May 2006
    Buffalo, NY
    Thanks Guino
    and MP3car is out of stock. I was thinking maybe one of the WinTV's might have had RDS sense a few advertise as picking up Digital FM signals.
    Does anyone no if you have to use the external mic or line-in to use WinTV or does the audio travel through the USB cable?
  1. RDS Radio in RR.
    By CherokeeChief in forum Road Runner
    Last Post: 01-07-2008, 10:44 AM
  2. RR and Axife (or other) radio player?
    By froop in forum Road Runner
    Last Post: 07-31-2005, 07:44 PM
  3. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  4. Radio for RR in CH
    By johnwrx in forum General Hardware Discussion
    Last Post: 06-04-2005, 04:43 AM
  5. RR & Radio Interface
    By BMVEE in forum RR Bug Tracker
    Last Post: 03-20-2005, 01:05 AM
