Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: problems compiling
    Oct 2003
    Copenhagen, Denmark
    problems compiling
    Hey guino
    I am trying to get started doing some adjustments myself to the code of RR, mainly to see if i could do anything for the speed of the current releases, but i am having some problems compiling. Do i need anything else than what is in the sourcecode zip file, some components that are not in the file maybe ?
    Regards
    Jan
    Not doing carpc anymore
    Raw Wave
    Jun 2004
    On the beach
    You need Mappoint I think it is to allow you to fully compile
    Oct 2003
    Copenhagen, Denmark
    oh i forgot to mention that i am getting a mappoint error when loading the project,mappointcontrol.ocx could not be loaded, which is understandable since that file is not in the source dir. also frmMPT.log says :
    "Line 34: Class MapPointCtl.MappointControl of control Map was not a loaded control class."
    In references under the project, i am seeing a few things checked, but some of them are not working.
    Microsoft Direct Speech Synthesis ? points to c:\windows\speech\xvoice.dll
    i downloaded the speech api 5.1, but there is no xvoice.dll file in there.
    Also, what should i install or do to get mappoint controls ? i would like to compile to a fully running version and not have to exclude any code.
    Oct 2003
    Copenhagen, Denmark
    just found the mappoint control ocx file and did a regsvr32, seems to fix that, also it would seem that the ms speech thing is a version 4 not a version 5.1 hence the wrong file names, i will get cracking on some coding :-)
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You'll still need mappoint installed to propperly compile the code.. you can run it inside VB without it installed. You'll also need the SAPI 4 installed (< 900Kb).. and Mapmonkey as well.
    Ride Runner RR's Myspace
    Oct 2003
    Copenhagen, Denmark
    got it installed now, and it compiles just fine. just read through modRoadrunner, holy crap thats a lot of case select for the skinning parsing :-)
    Oct 2003
    Copenhagen, Denmark
    my rr.exe is almost 1,8megs after compile, am i forgetting something really simple in the compiling ?
    Feb 2005
    Compiling in debug mode?
    Feb 2005
    Man I have a billion of these after I upgrade to .net 2003...
    'UPGRADE_ISSUE: Control DL could not be resolved because it was within the generic namespace Form. Click for more: 'ms-help://MS.VSCC.2003/commoner/redir/redirect.htm?keyword="vbup2072"'
    The upgrade_issue comments are what I have a billion of... some of them actually are a little differnet
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Good luck with the .net crap.. I woudn't touch that with a 12 foot stick.
  1. Still having XMPCR problems
    By rjoek in forum RR Bug Tracker
    Last Post: 09-23-2005, 01:08 PM
  2. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 07:12 PM
  3. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 04:04 PM
  4. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 03:37 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 01:55 PM
