Results 1 to 9 of 9
Thread: can't get CTRLLEFT/CTRLRIGHT to respond.
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    First off, let me say thanks to guino for building such a great app. When I first built my carputer, I was evaluating various frontends. Centrafuse had just come out, and RR wasn't around quite yet. I did try media car, however, and picked CF over it. Well, needless to say, i'm in this forum now, so it says quite a bit about the quality of Guino's work!
    Anyways, I've searched about this, but it seems i'm the only one w/ this problem. I can get all the other hotkeys working, but for some reason, I can't seem to get CTRLLEFT/CTRLRIGHT/CTRLUP/CTRLDOWN to respond. I've tried binding the hotkeys to a hundred different combinations, but the result is always the same.
    All that happens when I try executing them is the bottom most icon (vol down) is highlighted. I'm using the CF skin for Road Runner. The hotkeys work fine on my test machine (laptop) but in the car, i get nothing.
    Hopefully, someone can shed some light on the subject?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    are you actually pushing CTRL and LEFT? I know in the KeyTBL.ini file it says CTRLLEFT, but the actual key is just the arrow keys without any CTRL buttons.
    you should be able to just just push the arrow keys and use enter key to select
    post your KeyTBL.ini file
    beer replenishment fund
    mp3car live search
    Jul 2004
    Los Angeles, CA
    I tried a bunch of different key combinations, including the default 37,38,39, but it's still giving me problems
    I even took out all the entries below the skin commands section cuz I thought they might be interfering with the hotkey operation, but no luck...
    My install is a fairly default windows XP installation with a few powertoy tweaks.
    What's weird is if I RDP into the carputer from my laptop, everything seems to respond as expected. I was just wondering if anyone had run into something like this before.
    Attached Files Attached Files
    Apr 2005
    S.A.
    do you want the code for a skin or for an external app?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This sounds like a SKIN issue.. RR will move the mouse down to the bottom left when pressing KEYS, and that is most likely highlighting the button using that area on that skin. An easy solution would be to resize your skin to 800x599 or 800x479 (in general.ini of the skin).. The other option is to make sure you have no buttons using that last bottom left pixel of the screen (by editing the skin).
    Ride Runner RR's Myspace
    Jul 2004
    Los Angeles, CA
    Quote Originally Posted by SubaruWRX
    Sorry, not quite sure what you mean.
    Guino,
    Thanks for the advice. I'll try that and let you guys know how it works.
    Aug 2003
    Chicago
    also note: i took a look at your key file and you have them set to
    4037=alt + left arrow
    4039=alt + right arrow
    to only use the arrow keys without any modifier keys they should be like this
    37,"CTRLLEFT"
    38,"CTRLUP"
    39,"CTRLRIGHT"
    40,"CTRLDOWN"
    13,"CTRLEXEC"
    but the file looks fine to me.
    Its probably the button at the bottom left pixel thing guino was talking about, i had that problem before also
    mp3car live search
    Nov 2004
    St Louis
    Quote Originally Posted by guino
    This sounds like a SKIN issue.. RR will move the mouse down to the bottom left when pressing KEYS....
    Is there a way to turn this off? If so can we have the option to turn it on or off through the RRConfig?
    It didn't used to do this prior to August. I prefer the mouse to stay where I put it.
    Jul 2004
    Los Angeles, CA
    Yup, guino was absolutely right. It was the skin. The fix you recommended worked perfectly. Thanks again guino and LS. You guys rock!
  1. Replies: 5
    Last Post: 04-08-2007, 08:38 PM
  2. Navi Voice wont respond
    By vicky_obee in forum PowerVoice
    Last Post: 08-10-2005, 02:21 AM
  3. 2 gmail invites to first 2 who respond
    By Question in forum Classified Archive
    Last Post: 09-14-2004, 07:54 PM
  4. Slot DVD.....Please READ and respond
    By cenwesi in forum General Hardware Discussion
    Last Post: 06-19-2002, 02:12 PM
  5. AARON CAKE...PLEASE RESPOND!!!!
    By BeigeMaxima in forum General Hardware Discussion
    Last Post: 06-23-2001, 04:17 PM
