Results 1 to 7 of 7
Thread: How to set up background visualization?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I've been trying to set this up as i see others have it working without issues. I thought there would be a setting in rr.ini but i dont see one. I tried setting up a screensaver.ini but that turns ALL programs transparent. Can someone shed the light and clear this up for me please.
    Woodbridge, VA
    Blog Entries
    55
    hmm.. noone has this working?
    Sep 2005
    Georgia
    Yup, it's a bug in my code. can't remember if i sent it to guino or not, but maybe if you bother him enough he'll change it for ya
    Guino if you're listening, please switch these 2 lines in the APIstuff module so that the handle is saved inside the if statement:
    Vis_hwnd = target_hwnd
    If WindowTitle = "!Winamp Gen!AVS" Then
    to
    then only the winamp vis should be affected.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll do it as soon as I can... I'm waiting a repply from Skippy76 in order to start making more changes.. he's in Mexico or something right now..
    Ride Runner RR's Myspace
    Woodbridge, VA
    Blog Entries
    55
    oh ok ... and i thought i was just missing out
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by TheUni
    to
    Wouldn't it be a problem if you hardcode windows title? I would suggest using visuname in rr.ini instead.
    Well maybe I am wrong for whatever reason.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Sep 2005
    Georgia
    the reason it's hardcoded is because it really only works well with the winamp avs. the reason i coded it wrong, actually is because i was testing exactly as you said, with a variable in screensaver.ini, but i came to the conclusion that it's only worthwhile to have for avs. milkdrop, for example, requires that music is playing otherwise it gives an annoying popup.
    it's coded that way for a reason
  1. Recommend a set of 6.5" components...
    By hd54321 in forum Car Audio
    Last Post: 10-22-2005, 01:55 PM
  2. How to set Winamp visualization?
    By kebab in forum Road Runner
    Last Post: 08-31-2005, 06:23 PM
  3. 2 sub set up
    By GeeZeR in forum Car Audio
    Last Post: 07-30-2005, 01:26 AM
  4. How to set Freedrive directions volume
    By Phythorian in forum Road Runner
    Last Post: 07-28-2005, 06:35 AM
  5. Focal beryllium component set
    By RedGTiVR6 in forum Car Audio
    Last Post: 07-06-2005, 10:33 AM
