Results 1 to 10 of 17
Thread: Microphone feedback on XM?
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    When I have my USB microphone selected under control panel> sounds it works fine for recognition, etc. However when I go to XM radio in RR I get a super high pitched squeal.
    The XM goes to the line in on my soundcard, and I'm having RR unmute that line obviously. The Mic is USB.
    When I change the mic in the control panel to be the built in mic line in port (which has nothin plugged in) the XM radio sounds perfect.
    Obviously the mic is causing this high pitched squeal feedback somehow, but it doesn't do it any other time than XM play (mp3s work great, etc), and if the mic is disabled or unplugged XM works great.
    So what's goin on, and how do I fix it?
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Are you using the Line In Plugin ? or not ?
    I can understand the problem if you DO use the line in plugin, otherwise I have no idea. Maybe you should verify that the Mic is Mute for PLAYBACK.
    Ride Runner RR's Myspace
    Sep 2005
    San Luis Obispo, CA
    Yeah I am using the line in plugin.. i was under the impression that it was required for XM. Is there any way to have XM work without it?
    Where would I check the "Mic is Mute for PLAYBACK." ?
    Thanks for the reply.
    -arebelspy
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The line in plugin records from the DEFAULT recording source and plays back to the DEFAULT sound card. Basically, if you have the Mic set to record and have the line in installed, you'll be recording from the mic and playing it back and getting it back in the mic, and it will do what you're saying. You need to either stop using the line in plugin (and leave the sound card play the line in directly -- this depends on your sound card, it may not be possible for you), or make sure the Line IN is set as your record line -- this will prevent you from using the microphone for recording. Sorry but seems you're stuck...
    Those options are all controlled SOLELY by the windows mixer: Start->Programs->Accessories->Entertainment->Volume control. There are settings for Playback and for Recording -- you need to check them out and make sure you understand how they work. Sorry I don't have the time to explain it more than that.
    Sep 2005
    San Luis Obispo, CA
    Sounds like a problem with the linein plugin. No need to go into more detail on the advanced sound stuff - I got that all fine. If I unmute my linein plugin in windows it plays the xm radio just fine.. it's only when RR plays it that the high pitched squeal is added, so it must be that line in plugin that for some reason is mixing both the USB mic (being selected as the hardware in audio properties in control panel) and the line in that the xm is coming in to as well..
    So no one out there runs both a mic and XM?
    -arebelspy
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Search for AutoMute. I made that little program to mute microphone input automatically
    Jul 2004
    Berkeley, CA
    AutoMute
    Oh yeh... the mute on the mic merely means that the microphone will not be broadcast through the speakers. It will not affect SAPI
    Sep 2005
    San Luis Obispo, CA
    Oh sick, that's perfect, cause i was actually wanting the mic on to use with NaviVoice. You're a champ boris
    Trying to figure out the frodocomm stuff and automute now...
    -arebelspy
    Jul 2004
    Berkeley, CA
    Install Frodocomm. Set the service launcher to launch automatically at startup.
    Enjoy
    Sep 2005
    San Luis Obispo, CA
    Do I need to set both automute and frodo service launcher to go at startup or just the service launcher and that controls automute?
    -arebelspy
  1. Possible to split XM Direct cable to computer and XM commander?
    By Jemmi in forum General Hardware Discussion
    Last Post: 12-14-2005, 02:07 PM
  2. Pre-Release Thread: Frodo XM Service
    By frodobaggins in forum Software & Software Development
    Last Post: 08-04-2005, 04:10 PM
  3. Line Feedback
    By 2k5f150 in forum Car Audio
    Last Post: 06-09-2005, 08:34 AM
  4. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 02:18 PM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
