Results 1 to 9 of 9
Thread: MBM Sensors on a Via Epia?
    Jul 2004
    Santa Barbara, CA
    Hey guys,
    i'm having some problems figuring out the MBM. I've got my skin setup correctly i think:
    L03,660,10,50,30,255,255,255,18,"Arial Narrow:B","=Cpu:", ""
    L04,710,10,80,30,128,255,128,18,"Arial Narrow:B","MBM2", "C2F"
    L05,660,40,50,30,255,255,255,18,"Arial Narrow:B","=Vol:", ""
    L06,710,40,80,30,128,255,128,18,"Arial Narrow:B","MBM37", "0.00"
    But then now i'm starting to think that MBM2 is CPU load, and i'm looking to get the temperature... Does the epia M10000 have this feature?
    Also, i was thinking if i got a temp kit, i'd be able to measure temperature outside the car?
    And finally, is there a way to measure the voltage going into the power supply out from the battery? This would be a way to tell if my battery is dieing, yes?
    Thanks for all your input in advance fellas.
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm pretty sure you can read the info from the M1000, question is, did you install MBM and do you have it running when you tested the above ?? Can you read the propper values from within MBM ?
    The Temperature Kit would allow you to read any 4 temperatures you want (I have inside and outside of the car). There's also a Voltimiter Project by Mauri that allows you to read the Battery voltage (I also have that), they all work fine, but may require some skills in Electronics ..
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, you can read an Epia M10k, like guino says, all you need to do is when you install it is go to the bottom of the board list and select VIA and then select EPIA M1000 and all versions...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jul 2004
    Santa Barbara, CA
    hm, i've got the right board selected but i can't find the sensor for the temperature of the cpu. Nothing in Guino's little sensor program is anywhere near the range of temperatures i'd expect to see... i case is 12 and cpu is 25, i'm pretty sure that cpu is the cpu load not temp...
    -Ross
    02 Camaro SS
    Tot: $983
    Buying stereo!
    Aug 2005
    I have an SP8000E and this isn't officially supported by the last version of MBM at all - I chose one of the other VIA boards and eventually found one that worked and was stable.
    As far as checking what values mean what, I got *nothing* from the test app - I just played around with MBM itself until I found one that represented the CPU (higher temp) and the case (lower temp).
    There's fan speeds too in there if you've got 3-pin fans connected to your board. I've never seen a CPU load one on MBM though.
    aiml27
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    I had an M10000 and used MBM1 and MBM2 for my case and CPU temps, but I can't remember if that's the right order...
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    I have an Epia 10K too, and MBM1/MBM2 are giving me correct readings.
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Nov 2004
    Seal Beach, CA
    hey jrtf... you sure those numbers aren't in Celsius??
    2004 Toyota 4Runner Sport 4WD
    Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
    Jul 2004
    Santa Barbara, CA
    i thought for a while that they might be, but even when i convert them to fahrenheight, they come out to very low values for the temperature of a cpu...
    -Ross
    02 Camaro SS
    Tot: $983
    Buying stereo!
  1. Patch: Linux 2.6.11.6 on Epia
    By rubicon in forum Linux
    Last Post: 04-06-2005, 11:25 PM
  2. Pentuim M on DFI Vs. Epia Worth it?
    By alti in forum General Hardware Discussion
    Last Post: 12-04-2004, 03:05 AM
  3. Original Epia VS Epia M
    By MeanGT in forum General Hardware Discussion
    Last Post: 09-23-2003, 04:25 PM
  4. Getting MBM to work with EPIA ME-6000
    By MobileSuit in forum General Hardware Discussion
    Last Post: 07-21-2003, 10:40 PM
  5. Epia M and Epia 800 differences
    By wysiwyg in forum General Hardware Discussion
    Last Post: 12-20-2002, 11:50 PM
