Results 1 to 6 of 6
Thread: Where to start...
    Apr 2005
    Where to start...
    Hi all. New to this skinning stuff. I need some help.
    I've looked through this tutorial:
    http://venus.walagata.com/w/j187/How_To_Skin.ppt
    Im using RRSkinEditor
    I've played around with some other peeps skins to get the feel of how to modify them its just overwhelming and whatnot.When it comes around to making a fresh skin I must be missing something. I need a couple tips.
    Followed all the directions in the Tutorial and made a simple one button skin just to see if the button works, but when i try to load it into RR it says that its not a valid skin file.
    Here's what i think i could use:
    1. Simple basic, maybe 4-6 button skin that does not have a bunch of stuff. Just something to get me started and an idea of what im doing wrong. Mostly just some thing to compare and reference other than the completed ones that are, like i said overwhelming.
    2. a link to a small simple skin that is like the one i described above.
    I know what your thinkin... darn NOOBS,lol.
    Thanks in advance.
    Rosebud
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    IF you want to play around with skins, the best suggestion is to COPY an existing WORKING skin onto another folder and start making changes to it, then replacing screen by screen with whatever you want. You most likely didn't create a general.ini file which is required.
    Ride Runner RR's Myspace
    Sep 2005
    Quote Originally Posted by guino
    I didn't create a general.ini
    RRSkinEditor creates one for you doesn't it?
    Apr 2005
    Yes it does. But I still got the error saying it was not a valid skin.
    I have played around with other ones and i wanted t otry and make one for myself.
    This is what i have and getting the error with
    Again, this was just a test button to see if it would work.
    SKIN:
    MEDIACAR Skin
    Menu_off.jpg,Menu_off.jpg,Menu_on.jpg,Menu_down.jp g
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L,0,55,146,19,,,,12,"Arial","=Minimize","SCROLL-CENTER"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,3,47,145,32,"=MINIMIZE",
    END
    GEBERAL.INI:
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    XPosition=0
    YPosition=0
    ApplyToVideo=False
    ApplyToVisu=False
    AutoSwitch=False
    DayTime=8:00:00 AM
    NightTime=6:00:00 PM
    GammaDayRed=1
    GammaDayGreen=0
    GammaDayBlue=0
    GammaNightRed=-40
    GammaNightGreen=-40
    GammaNightBlue=-40
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The only thing that I noticed is that the skin file should have 3 lines in the begining(?), or at least all the ones that I have seen/played do...ie:
    MEDIACAR Skin
    MEDIACAR Alpine"Contacts" skin
    hopefully someone that is more into skinning/modifing will point ya in the right direction
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jul 2004
    NL, Druten
    Hi Rosebud6.
    just like guino said; download a skin you like, copy it to a new directory and start playing around with SkinEditor and your Notepad. It's not that hard. It does take a lot of time to gather all information. Most of the documents are up to date C:\Program Files\Road Runner\*.txt. Other information is around this forum somewhere. How do I start?
    First off all I make a design in Photoshop. I export the images of the first screen. This contains normaly the startup screen. I make at least 2 buttons, audioplayer (next to build screen) and skins (to switch/reload skin). This first screen could be basic for a lot of screens (e.g. player buttons) these buttons, play, stop, ff wind and so on.. I copy with notepad to the audioplayer screen. this way I know these buttons are exactly the same size height....and so on.
    Biggest tip I got for you.. stealing..
    Download a lot of skins and learn from others :P
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 09:44 PM
  2. Failed Hiding of Start Bar, Minimize Errors
    By DaRacerz in forum RR Bug Tracker
    Last Post: 11-04-2005, 04:36 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  4. Can't get MediaCar to start up with windows
    By EuroFan in forum MediaCar
    Last Post: 10-19-2004, 03:48 PM
  5. donīt start
    By martin83 in forum Power Supplies
    Last Post: 09-13-2004, 02:24 PM
