Results 1 to 10 of 10
Thread: Loading a winamp plugin into a RR Skin (DFX)
    FLAC -zip-'s Avatar
    Ontario/Canada
    Is it possible to load a winamp plugin into a skin with no .exe? I have resized the winamp DFX skin to 800x600 so it is more touch screen friendly.
    Class Name: DFX_WINDOW
    Caption: DFX 7.5 Winamp
    but it runs a .dll
    I would also like to expand on this like the lyrics plug in etc.
    Sound Stage
    Eclipse|MTX|Infinity
    Jul 2004
    NL, Druten
    now thats a good idea.. my girlfriend would sure wasnts this feature!!!
    Been playing around with it and have to say it really rocks!
    Constant Bitrate dbassix's Avatar
    May 2005
    Dresden / Germany
    Could you Post your 800x600 Skin for DFX?
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
    FLAC -zip-'s Avatar
    Ontario/Canada
    Will do as soon as I get home from work. It is the standard DFX skin for winamp but much larger.
    Any ideas on how to integrate it into RR?
    Sound Stage
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    Why do you want to? I use DFX but have the settigs done and have it minimized so I never see it. I guess you constantly change the settings?
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I believe what you want to do is EMBED the plugin's window onto RR. This can be done but depends on the plugin. And you'd have to find a way to start it (bring it up) when you need it. As long as you have a defined window title, it should work.
    Ride Runner RR's Myspace
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by arebelspy
    -arebelspy
    DFX works well at low volume, I have 1100 watts running 2 amps. So I like using DFX when the music is low it gives a more full sound, but at ear bleed volume it will cause distortion, so you are correct I adjust it a lot.
    Sound Stage
    FLAC -zip-'s Avatar
    Ontario/Canada
    Here is the link to the 800x600 DFX skin. I have disabled the help and DFX logo link to the website as there is no need for either.
    http://www.savefile.com/files/9269470
    Sound Stage
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by guino
    Thanks G,
    I have the windows name, I am used to embedding stuff with a program .exe. in my first post I have windows and class names but in the embed FAQ it does not show you how to do this when there is no .exe file to embed
    Sound Stage
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If there's no EXE, you just have to set the window name on the LOAD command and if RR finds it, it will embed it. This would actually be similar to what happens with normal Vis plugins, you can easily specify the VIS name on the LOAD command for the audio player, and when you press the command to start visualization, RR would find the window and embed it.
  1. How do I setup the CD Rip plugin ?
    By guino in forum RR FAQ
    Last Post: 12-18-2008, 07:28 AM
  2. Replies: 3
    Last Post: 11-23-2006, 10:14 AM
  3. Occasionally winamp uses almost all the cpu slowing down RR
    By Arathranar in forum RR Bug Tracker
    Last Post: 03-21-2005, 11:38 PM
  4. Replies: 8
    Last Post: 11-30-2004, 01:07 AM
