Results 1 to 10 of 11
Thread: Changing volume at startup?
    Dec 2005
    When I start RR I can hear stuff just fine, However, if I change the volume up or down I lose sound. To get it back I have to bring it down to 0% and then back up to what I want. Now I only have to do this once, after that, I can change it however i want.
    So is there any way i can have RR automatically do that when it starts up?
    Sep 2005
    guino tells me this is a sound driver problem. I have the same problem. Updated my sound drivers and problem persists. You don't have to turn the sound all the way to 0% do you? Mine just jumps to 0% when I adjust sound, and it goes up from there. But it will still read sound at like 90%...
    Dec 2005
    Yeah thats basically what i got from the forum, but if there was any way to make it so that RR could lower and raise the volume at start, that would be an adiquit workaround. It happens on both my computers one with a SBA2 (newest drivers, and the old ones it came with) and my laptop with the drivers XP MCE gave it.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can try the SETVOLUME command at startup to see if it helps, but I can tell you that if the code works for most, there's nothing wrong with it. But you can always try an old version of RR to see.. but nothing has changed in the longest time.
    Ride Runner RR's Myspace
    Sep 2005
    This happens on my laptop and my carputer
    I don't know what to try to fix it.
    If the setvolume works, I might just do that. It could also avoid me destroying my eardrums or having a heart attack when starting the car back up after I have been doing interstate travelling
    Sep 2005
    Is SETVOLUME a new command? I think my laptop has an older version of RR, and I can't find the command in skin commands.txt
    what is the format for the command?
    would i say, for instance, "SETVOLUME;15" or "SETVOLUME;15%"?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    relatively new, yes, it's there on skin commands.txt
    Constant Bitrate 2 STanGeR's Avatar
    Aug 2005
    Terre Haute, IN
    I was having the same problem, but fixed it by setting the "Map Master Volume to Control Line "All Lines". This fixed my issue, so hopefully it wil fix you guys too.
    Sep 2005
    Interesting, I looked in RRConfig and mine was set to map master volume to control 'all lines.' I changed it to map to 'master volume.' And it fixed mine. I dont know if thats the same thing you meant, or if my situation is opposite, but thanks for the tip. It worked.
    Aug 2005
    Terre Haute, IN
    Opps, I must have deleted my text. It was supposed to say that I changed mine from "All Lines" to "Master Volume". Glad that you figured out your problem.
  1. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 12:55 PM
  2. 03 VW Jetta GLI
    By Hans Delbruck in forum Worklogs
    Last Post: 11-27-2006, 05:13 PM
  3. Problem: Master Volume at 100% at startup
    By digitboy74 in forum Road Runner
    Last Post: 05-03-2005, 03:24 PM
  4. Changing Volume in Frodo
    By Jstarko0329 in forum PowerVoice
    Last Post: 12-15-2004, 07:17 PM
  5. Safe Volume at Startup Feature
    By shakes in forum MediaCar
    Last Post: 04-15-2004, 10:55 PM
