Results 1 to 6 of 6
Thread: Set Port Used By RR?
    Raw Wave
    Jun 2002
    Virginia
    Anyone know how to tell RR what serial port to use? This is the port RR uses for the speed indicator, etc. I have Iguidance successfully working on port 4, but that apparently conflicts with RR because the RR speed indicator doesn't work. I'd like to be able to tell RR to use port 5, but haven't found the way to do it. Any help would be appreciated.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    have you by any chance ever loaded up RR.config.exe?
    beer replenishment fund
    mp3car live search
    Aug 2003
    Chicago
    ok, assumeing you did load RRConfig, you had to at least once.
    Look under GPS, its a little confuseing if you dont know, but basicly set your GPS Mode to Mappoint (even though you are using IG) then set the GPS port to 5
    mp3car live search
    Raw Wave
    Jun 2002
    Virginia
    Yes, I had loaded the configuration file dozens of times and read every line of rr.ini multiple times and didn't see anything related to the rr com port. I see from your post that it's the MapMonkey setting that's relevant. Thanks.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    in RR config, what is your selection for GPS?
    If you select Map Point and port number, the indicator will works.
    If you select Any other than mappoint (External for IG), the indicator will NOT works.
    Here is how to work around.
    Open RR.ini and add the following line.
    MappointPort = 5 (5 if GPS data is also available. Use Xport3 for that.)
    Okay, all should work. But remember, when you run RR config again, and gps selection isn't mappoint, that mappointPort line will be erase.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Actually, Setting the port to Mappoint or to Menu will save that setting. Setting it to Map Monkey or to External will not save the setting. I"ll try to change that for next release.
    Ride Runner RR's Myspace
  1. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 05:47 PM
  2. Port Com in RR!BUG??
    By sevensad in forum Road Runner
    Last Post: 11-29-2005, 04:45 PM
  3. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 02:58 PM
  4. girder on RR
    By mick0uziel in forum Road Runner
    Last Post: 03-29-2005, 08:00 PM
  5. Spliting power on a PS/2 port...
    By Defiler in forum General Hardware Discussion
    Last Post: 02-27-2002, 04:02 PM
