Results 1 to 6 of 6
Thread: Sending IR Singals with RR & USB-UIRT?
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    Okay, I want to control my head unit using IR Signals. I already have GIRDER up and running with a USB-UIRT and a IR stearing wheel remote. But I need to find a way to send a trigger to Girder from RR. (I can already control my head unit with Girder and the USB-URIT)
    So in the end, I want to push a button on the screen which would have RR send Girder an event, then Girder would produce the IR code via the USB-UIRT.
    Any Ideas guys?
    May 2005
    Vienna, VA
    use Girder's event.exe. Make the RR button do something like this.
    "RUN||C:\Program Files\girder\event.exe your_event_string -silent"
    The -silent is there so that you don't get a Command Prompt window.
    Just verify the syntax.
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Let me know if this works... want to do the same with my DTT TV Receiver..
    Terran
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Girder newbie here... I want to control my HU via girder/RR so that I can use steering wheel to control HU volume rather than Winamp/Windows volume. Can someone please verify my plan?
    Previous setup: BMW steering wheel press "volume up" button sends IBus command "VOL+" to RR, which increases the volume coming out of winamp. This currently works great.
    Desired setup: Steering wheel press "volume up" button sends IBus command "VOL+" to RR, RR in turn translates this into executing girder event.exe (as specified above) for sending IR command to my HU to increase volume. I would put this "VOL+" translation in the ExecTBL.ini file at the c:/Program Files/Road Runner level, and it would go something like this: "RUN||C:\Program Files\girder32\event.exe VolumeUp -silent", which if I set up Girder correctly, should use my USB-UIRT to transmit the IR code for increasing the volume to the HU, and WOULD NOT increase the WinAmp/Windows volume.
    Is this right?
    Feb 2005
    Atlanta, GA USA
    Well, after trying what I proposed above, I'm not getting anywhere. I've put the following entry into my ExecTBL.ini:
    "VOL+","RUN||C:\Program Files\girder32\event.exe VolumeUp -silent"
    When I press the volume up button in my skin (which is mapped to "VOL+"), I get nothing. Here's my GML that I'm working with:
    PioneerDEH-P5800MP.txt
    I'd appreciate any suggestions on what I'm going wrong.
    Feb 2005
    Atlanta, GA USA
    NM, figured it out - the entry goes in the top-level ExecTBL.ini, and it should be:
    "VOL+","RUN;event.exe|VolumeUp -silent"
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 01:55 AM
  2. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
  3. FS - USB IR Sensors For Standard Remotes
    By ccsnet in forum Classified Archive
    Last Post: 05-13-2003, 08:09 AM
  4. Wanted Some One To Make This USB IR
    Last Post: 05-11-2003, 05:43 PM
  5. USB IR Reciever?
    By orangewhip in forum General Hardware Discussion
    Last Post: 07-19-2001, 06:25 PM
