Results 1 to 3 of 3
Thread: Loading Playlists
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    Loading Playlists
    I havent been on in a while, but I was finally getting annoyed with not being able to put save a playlist in a seperate folder than the music path. If i direct the playlist path to the music path, then it saves in the same folder, and the saved playlists show up at the bottom of the music list.
    I wanted to save the playlists in a seperate folder, and then be able to call up a seperate screen that would have only a directory list of the saved playlists. This way i could have a more organized way of saving and loading playlists.
    I tried to use the directory list in the skin editor but it doesnt seem to be set up the correct way in which i can define the path. I tried manually to set it up based on the skincommands.doc but that did not work either.
    Utlimately i want to push a button, call up a screen that lists my saved playlists and be able to scroll through them.
    If this is answered or discussed, or rather simple and i have missed it i apologize. I have been up for nearly 2 days now for very random and odd reasons. Thanks fellas.
    throw a moon
    heuvos vin chevos
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You CAN do that with the latest versions of RR. Read up on the SD definition for the skin files. It allows you to make a custom file Browser with a defined style and defined location to start with.
    Ride Runner RR's Myspace
    Aug 2004
    tx, USA
    PERFECT!!!
    doing it now
    thanks broham
    throw a moon
    heuvos vin chevos
  1. Loading browser to a specified path
    By RoyN in forum Road Runner
    Last Post: 04-06-2005, 11:59 AM
  2. Playlists & Playlists path
    By Gobby in forum Road Runner
    Last Post: 03-30-2005, 01:38 PM
  3. Playlists 101
    By PDiddy in forum FrodoPlayer
    Last Post: 01-19-2005, 07:19 PM
  4. Winamp slow when loading playlists and 'jumping to file'
    By bayere in forum Software & Software Development
    Last Post: 06-25-2004, 09:37 PM
