Results 11 to 20 of 22
Thread: RR Questions
  1. #11
    Variable Bitrate NeoMatrixJR's Avatar
    Aug 2004
    Arround Des Moines, IA
    Don't know...didn't install AVS last time arround
  2. #12
    Aug 2004
    Ok, fixed the shuffle, and repeat icons...removed the CD icon (it's not implemented yet I guess)....now I'm just down to winamp viz...I may try and re-install winamp with AVS
  3. #13
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    for the vis problem, make sure winamp is not set to use modern skins, it has to use the clasic skin as the window name changes between the two.
    beer replenishment fund
    mp3car live search
  4. #14
    Aug 2004
    Oh, well...right now I'm using modern skins...but AVS seems to be working now even with the modern skin. I do have a new question. I just installed mappoint (yeah...not the best, but I've already got it) but when I click on GPS nothing happens. Any Ideas?
  5. #15
    Aug 2004
    bump...any gps/mappoint ideas or suggestions? Thanks!
  6. #16
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    did you select Mappoint in RRConfig ? can you launch it outside RR ? what version are you using anyway ? (2004 is the only currently supported).
    Ride Runner RR's Myspace
  7. #17
    Aug 2004
    Yes, it's selected in RRConfig, I believe it will run outside RR...can't remember if I checked (), but I'm not @ home right now to test it, and I'm running 2004.
  8. #18
    Aug 2004
    Yep...it launches outside RR fine...Do you have to have MapMonkey w/ Mappoint?
  9. #19
    Aug 2004
    wait...I may have it...is there supposed to be a specific skin for Mappoint? The skin I'm using doesn't have one...
  10. #20
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you only need Mappoint, and a SKIN that supports it. the Brushed skins do.
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. RR 09-09-05 ... Yup, it's my Birthday!
    By guino in forum Road Runner
    Last Post: 09-12-2005, 06:05 AM
  4. Questions about RR config
    By Enforcer in forum Road Runner
    Last Post: 07-21-2005, 12:48 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
