1. look in the config you can change this to not shuffle or repeat.
2. You need to direct the path to your drive in the skin sorry I am not at a windows machine or I would give you the correct path.
3.firefox 1.5 cannot be embedded right now if you still have the older version it will work fine otherwise you must use IE
4.Winamp visuals should just be a matter of giving the correct name in the config window. Check the general config in the rr config utility.
5. I don't use radio so can't help ya there.
LinkBack URL
About LinkBacks
