*cough FAQ: Boot directly into your front end
Confusion says: while one maybe impressed with a newbie bringing great new ideas to a forum, one also appreciates more one who's first.
*edited to add Confusion says in front to turn into a wise saying
Hi all,
Thought I would share with you all, how I have been able to run RoadRunner as a shell.
N.B. messing with your shell can screw up your computer
Step 1
Create a new file using notepad and put in it any programs you would like to run at start up, again in my case this is;
start "BtTray" "C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe"
start "PowerStrip" "C:\Program Files\PowerStrip\pstrip.exe"
start "RoadRunner" "C:\Program Files\Road Runner\rr.exe"
start "Mouse" "C:\Program Files\3DMouse\3DMOUSE.EXE"
start "DirSync" "C:\Program Files\DirSync\DirSync.exe" /Background
start "ATI" "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe"
start "Keyboard" "C:\Program Files\MediaKey\MEDIAKEY.EXE"
start "PowerDVD" "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
start "Konfabulator" "C:\Program Files\Pixoria\Konfabulator\Konfabulator.exe"
save this file as start.bat and remember where you saved it (I put it in c:\WINDOWS)
Step 2
To get this work open task manager>File>NewTask
then type regedit and hit enter, or start>run then regedit and hit enter. Once regedit is open go to HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows NT>CurrentVersion>Winlogon then look for the key shell in the right hand pane. Double click on shell and change the value data: path to match where start.bat is, in my case this would be "C:\WINDOWS\start.bat" N.B. make sure you have the quotations around the path or it won't work!
Hope this makes sense and is of use to someone. Any comments or questions are welcome,
cheers,
Angelus
I appreciate that I am new, as a poster to this forum, and that I have posted roughly the same instructions in two differnet places. I also don't want to start any arguments, but I hadn't found any decent instructions about creating a start-up batch file, and hoped this might save someone the searching that I had to do.
Again, no offence is meant to any-one and having used some of enforcers posts before I definately don't want to annoy him/her.
Confusion Says: Man must not read too much into wise sayings and must sometimes look at smiley face next to them to gain true meaning.
This and many more can be viewed here
Confusion?
this whole time I thought it was Confucius.
Originally Posted by wizawuza
I see the confusion is working then.![]()
Ignore him - he got PTSD from the great war.....
Originally Posted by Spaghetti
....m front that was known a Melinda Messenger.
