changes to the skin (i think you can change the skin and change it back) but i dont remember for sure. actually that might only change the jpgs not the coords.. or vice versa. i guess you could try itOriginally Posted by d_sellers1
Is there any way to force a skin to re-load on the fly. I've been making changes to zots.day skin to get it set up the way I perfer. However, any time I make a change, I have to close RR and restart it in order to view the changes. This really sucked when I was working on the GPS.skin. I'm looking for some sort of key combination that will force RR to reload the .jpg and .skin files for the skin (Guino: hint, hint) since these files appear to load into the memory when you view them for the first time (per session).
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
That requires a bit more effort than what I'm looking for. Then that means I would have to select the skin that I'm currently working on. I'm looking more for something like F5 (Refresh) like everywhere else in Windows.Originally Posted by lostreception
Derek
There is an option to do this in the beta 11c release http://carpc.harteveldt.com/ scroll to the bottom.
- Added "RELOADSKIN" command for skinnersOriginally Posted by DoubleC
That's exactly what I'm looking for (depending on how it's implemented). Curious of the date of this beta. Guess I'll just have to find out when it's done downloading. Thanks.
Derek
its in the current release (11-27-05)
add this to your KeyTBL.ini file
116,"RELOADSKIN"
and use F5 to reload the skin
beer replenishment fund
mp3car live search
I just found this. It works a treat. I made a temporary button, and just used it to releoad the skin I'm working on.
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Cool. I spent some time with it today. I added a button at 0,0 and a size of 2,2. Basically it's something that you won't hit with a touch screen but can get with a mouse (like what I've been using). Works like a charm. I will have so check out the F5.Originally Posted by liquid_smoke
I've been playing a little with the KeyTBL.ini and was able to fix a problem that I was have with the VISU when jumping for Menu > Audio and vice versa. I was having lots of problems getting my AutoIt script to work right but when I added hotkeys for the Menu and Audio screens and VISU, it worked perfectly and was a lot less complicated.
Derek
Damn, I wish I found this earlier - I've reloaded RR/FD so many times I'm sure I've worn a groove on my hard drive!
I use the "DAYNIGHTSKIN" command on a button in day and night skin to change to other skin then back which in effect reloads the skin.
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAMold carPC
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
