Results 1 to 9 of 9
Thread: Music Sort order / Display
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    In the RRconfig there's a section to define the ID3 tags for browse and playlist. But what determines the ORDER the songs are displayed in? Is that definable as well? I'd REALLY like an option to sort by artist or title while I'm in RR itself.
    Also is there somewhere that defines the effects of the various ID3 settings?
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    this would be really nice, to add a way to sort the playlist, instead of having it appear 'random' or by directory order only
    thanks
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    Nov 2004
    St Louis
    Download Chuck's skin and take a look at his music player.
    Mar 2004
    Los Angeles Area
    Wow, Chuck's skin takes RR to the max! It'd be great if I had a 21" monitor in my car and someone to drive while I play with RR. I checked out the audio player and the only thing that even appeared to re-sort the list was a button labeled "ABC". When I clicked it, my list did change somehow but then my comupter was locked up and I couldn't explore further. I believe the command for the button was:
    B09,099,180,65,65,"ACTIVATE;Playlist Editor||SENDKEY;^+1||RELOADLIST",""
    I'm not exactly sure what the above does, but I don't see that it would toggle artist/album in the sort order.
    Basically I'd like to toggle the listing between: 1. Sort and display just the titles; 2. Sort and display Artist - Title. Is this possible???
    May 2005
    Vienna, VA
    No, it's not possible.
    Winamp only allows you to sort by title or filename. But if you name your files as "artist - song.mp3" like most people do, you can sort by filename and get the same effect as sorting by artists.
    Mar 2004
    Los Angeles Area
    My filenames are all artist - title. If I can't have RR toggle the sort order, I'd like to have it show them all in just title order, then if I want a specific artist I can do a search to filter them out. No matter what I do though, my songs always appear in artist-title order in RR (even if I only display just the title). I went into Winamp and checked "When loading multiple files sort by name" but that didn't help either. How can I get the lists to just sort by title?
    Mar 2004
    Los Angeles Area
    Quote Originally Posted by b8bboi
    Is it Winamp then that determines the sort order? My Winamp playlist has the following options in it:
    Code:
    Sort list by title
    Sort list by filename
    Sort list by path and filename
    Reverse list
    Randomize list
    Why can't RR invoke these commands for the selected playlist and put the songs in just title order?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Check has the randomize feature in his skin.. it's only a matter of programming the keys.. the problem is that RR will reload the ID3 Tags afterwards (if used) since the playlist changed (fine for small playlists)... the best approach would be to implement those in RR itself.
    Ride Runner RR's Myspace
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    You can only sort these ways that i know of
    Buttons
    "ACTIVATE;Playlist Editor||SENDKEY;^+1||RELOADLIST",""----------------sort by tital
    "ACTIVATE;Playlist Editor||SENDKEY;^+2||RELOADLIST",""----------------sort by file name
    "ACTIVATE;Playlist Editor||SENDKEY;^+3||RELOADLIST",""----------------sort by file path and name
    "ACTIVATE;Playlist Editor||SENDKEY;^r||RELOADLIST",""----------------Reverse Playlist
    "ACTIVATE;Playlist Editor||SENDKEY;^+r||RELOADLIST",""----------------Randomize Playlist
    this one will do both sort by tilal then randomize - 3rd button down
    ,"ACTIVATE;Playlist Editor||SENDKEY;^+r||RELOADLIST||SWITCHBUTTON;3>>A CTIVATE;Playlist Editor||SENDKEY;^+1||RELOADLIST||SWITCHBUTTON;3"," "
    2001 S10 ZR2
    Chucks Skin - to old
  1. Replies: 38
    Last Post: 12-31-2005, 06:39 PM
  2. Order music is added to playlist
    By djXternal in forum FrodoPlayer
    Last Post: 09-10-2005, 11:04 AM
  3. Replies: 5
    Last Post: 08-25-2005, 09:45 PM
  4. Dual Display Problem on M-II w/PowerDVD
    By DrDeriv in forum General Hardware Discussion
    Last Post: 04-11-2005, 06:16 PM
  5. Replies: 2
    Last Post: 03-01-2005, 01:59 PM
