Any chance of a copy of the older buttons?? Prefered them much more than the current ones ... sorry to be a pain.
Update 1-5-06 - see post #2 for new .swf files
lostreception was kind enough to send me his .fla file or this grate app he made with all the fixes…… thx lostreception
So I have made some draw&save.swf files with all the fixes - left side menu – bottom menu – small left menu.
If someone needs a different one just let me know
My type buttonsOriginally Posted by Gobby
wow nice work with the different versions
ive been so busy i only had time to write it thanks alot for supporting it and making some real nice changes
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
I extracted the swf from drawsmleft.zip and doubleclicked it to run it. It is the first one I've found that saves the drawings. Don't know why the exe and other swf's didn't but I'm happy with this one anyway. The problem is, how do I run the swf instead of the exe from RR? Here's my button command line for the exe:
B,401,176,400,111,"LOAD;EXTERNAL_GPS.SKIN;Sketchpa d;C:\PROGRA~1\ROADRU~1\LAUNCH\DRAW\DRAW&SAVE.EXE;! ShockwaveFlash!Draw"
I've tried replacing the exe with swf with no luck. How do I run a swf from within RR?![]()
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
I'd make a copy of the "EXTERNAL_GPS.SKIN", Name it Scratchpad.skin.
Then copy the SWF into the root of your skin then add a "FLASH" window on the "scratchpad.SKIN" and just put in "DRAW&SAVE.SWF" (or whatever the name of the .SWF Is) in the "Movie name" Field
,and the button would just need:
"LOAD;scratchSWF.skin"
This eliminates the need for a path in the command line. Only problem is if you use more than one skin (IE: BMV2, and MC2) you would have to make a new scratchpad.skin for both.
Thats how I did mine anyway.
please .... help needed, why I get this with the latest release of this wonderful tool ? Is it something related to flash player (mine is version 8)? I got the same when I try to use directly the swf file from outside RR; when I use the exe version all work fine .... !?!?
Try the bottom menu one in post #2 and let me know if it works the same wayOriginally Posted by lucianop
thx
Thanks Chuck, looks much better nowOriginally Posted by Chuck
Well done on such an amazing flash app .... you too lostreception and anyone else that contributed.
@chuck
... same, I've tried with the one by lostreception and your three modified versions, and it's always the same. And furthermore I cannot draw on the right side of the pad, about 1/4 of the width (my scratch area is 800x400, is it a wrong shape ?) ...
