When I do that it's still only working half:
add the flashfile in rr
chuck i sent you a pm but the instructions are incorrect
i misunderstood you at 1st
dont delete the box you need to make it larger you changed the size of the movie but not the hidden fix layer i used to fix the swf embedded problem
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
For those intrested; I've attached a jpg of the chalkboard I used in the picture above.
One usability issue I'm seeing. I'm using the version from post 100... so I think that's the newest. Anyway, everything works great except when I save an image or a few, close road runner (say I shutdown the computer for the night) then next time I start up the app, I'm taken to image 1.
Just based on how any other application acts, I'd expect to be taken to new blank screen. If I then want, I can click on the back buttons to see my old drawings (I'm mainly using this to write down phone numbers and addresses and such) I only want to look back at them when needed.... When I open the program I can see it will eventually get annoying if I have to press through all of my old images just to get to a new image.
Would this be an easy modification?
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
i wrote it with that function in mind i removed it at the last minute
i can put it back in easily
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
If you could, that'd be great!
Matt Atkins
'98 540i-6 blk/blk
Ok , I will hold off updating everything till I hear from you lostreceptionOriginally Posted by lostreception
here it isOriginally Posted by Chuck
Update 1-8-06
All files in post 2 are updated
Last record saved
This will make it so the last record saved will be the 1st one to come up
Restricted area fixed again
Added button down
Thx lostreception for the update
