looks goodnice job
the files of the one above
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! this file was updated !!!!!!!!!!!!!!!!!!!!!!!!
looks goodnice job
beer replenishment fund
mp3car live search
file was updated above - post #23
Good work!Originally Posted by Chuck
Is it possible to you create a file .exe to be launched with APPS of RR of this
application and put in download?![]()
Mauri
Heres an exe just designed to run the swf file on opening.
Extract the zip to the root of c:\ then run the exe
Embedding string is: DoodlePad
Hope this helps.
Edit: Oops, Chuck has already done an exe, will leave here just in case ... sorry Chuck, didn't mean to butt in.
What did you make the exe with?Originally Posted by Gobby
Forgive me but, how do I run the swf inside the "Doodle Pad"?Originally Posted by Gobby
"If at first you don't succeed, keep on suckin' till ya do succeed" (Stooges)
Ok, embedding works with RR, but it goes out of the area of settings "application" of my skin.Originally Posted by Chuck
The .ini that I have written its ok this way?
[GENERAL]
PATH = C:\Draw\Draw.exe
TryEmbeddedTimeOut = 5
WindowSearchString=Draw
EDIT:is it possible don't view,embedded to RR,the active bar of the top and close the application with the exit command of RR skinned with one button?
Thanks![]()
Mauri
Change WindowSearchString=Draw to this WindowSearchString=Macromedia
Ahhh,ok ,work!Originally Posted by Chuck
Edit :is it possible to add one another button for save the draw or text written,exsample in .gif format?
It for use the application for fast notepad and remember what I was written....![]()
Mauri
