Page 7 of 21 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 204
Thread: Paper and pencil
  1. #61
    Raw Wave lostreception's Avatar
    NY
    Quote Originally Posted by wysocki
    Same here. I put this command on a button in my main screen (and used my iGuidance skin) for it.
    B,401,176,400,111,"LOAD;EXTERNAL_GPS.SKIN;Draw;C:\ PROGRA~1\ROADRU~1\SKINS\DRAWANDSAVE.EXE;Draw"
    Does this look ok? The app doesn't come up on my XPsp2 system, but it will start by itself.
    try
    B,401,176,400,111,"LOAD;EXTERNAL_GPS.SKIN;RUN;C:\PROGRA~1\ROADRU~1\SKINS\DRAWANDSAVE.EXE;Draw"
    if that doesnt work try going without progra~1 and type it out in its entirety
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  2. #62
    FLAC mauri's Avatar
    Jan 2004
    Tested,skinning the buttons for my use, and work PERFECTLY embeddded with RR and APPS application launch ....best work!
    Mauri
  3. #63
    Low Bitrate Clarre's Avatar
    Feb 2005
    Hedemora/Dalarna/Sweden
    What can I do for having the save&draw open in fullscreen? IMO I've got a larger textarea.
    Via Epia M1000
    512MB RAM
    120MB IBM Hard drive
    Netgear MA111
    Lilliput 8" Touchscreen
    http://www.clarre.com/carcomputer.htm
  4. #64
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Ditto, another plug for working perfectly in RR, in Apps, and embedded in it's own window.
    Here's the code I used to give it it's own dedicated button on the MAIN page using the IG skin, same as you:
    B15,113,10,60,70,"LOAD;draw.skin;;c:\drawandsave.e xe;Draw"
    I found I needed 2 semicolons after the skin name. The format is (I think) "load;skinfile;verbalcommand;filelocation;embedded windowname"
    I wussed out & just put it under C:/ though. If my code doesn't work, try it with the prog in C:/, then once it works put it somewhere else & see if you need to spell out the directory name.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  5. #65
    Jun 2002
    Virginia
    Quote Originally Posted by Escalade182
    chuck, how far is ocean city and frederick from ellicot? sounds so familier I just cant seem to remember where it is.
    About 150 miles west of the ocean and 45 miles east of Frederick.
  6. #66
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Ok, now I'm going to take this to another level!! Wouldn't it be nice if you could use NaviVoice and have this write for you as you speak? I mean think of it this way; you're driving and you get a call and have to take a number down. You bring up this app, say the text and it writes it down for you and save it. Perfect!!
    What do you think guys?? Is this even possible?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  7. #67
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Update 1-3-06
    Thanks to lostreception this is the greatest
    see post #1
    2001 S10 ZR2
    Chucks Skin - to old
  8. #68
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    awesome little app....thanks Chuck and lostreception.
    My $1200 etch-a-sketch is finally in place
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  9. #69
    May 2005
    I use this code on my button:
    B09,0,460,160,70,"LOAD;scribble.skin;;c:\draw\draw andsave.exe;Draw"
    The scribble.skin screen opens, but the draw app isn't visible. (doesn't appear to start at all) The path c:\draw\drawandsave.exe is correct.The app works fine when I click the .exe outside RR. What am I doing wrong?
    Edit: Hmm, don't I need some indicator on the scribble.skin to define where drawandsave.exe is shown? Which label should I use?
  10. #70
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    you need to add something like this to your draw skin
    /, A, x, y, w, h, color;RGB
    A,17,98,600,415,
    2001 S10 ZR2
